Ever Seen an AC D-17 on Steel????
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Ever Seen an AC D-17 on Steel????
    Posted: 16 May 2010 at 7:34pm
Just discovered this tractor this afternoon at a used tractor sales lot.  What's it worth?  I doubt if I would get a flat tire bushhogging a patch of thorns with this one.  Are these factory wheels?
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:38pm
I'm not an expert, but they don't look factory. Looks like they welded channel iron to the hubs.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:40pm
They'd be okay in a plowed field,but would be a rough ride on a gravel road! LOL! I've never seen or heard of a D17 on steel before personally...I think they're homemade.  If so,they did do a good job of fabricating them though.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:43pm
I don't know if it is factory or not,but I do like the Idea of being able to bush hog thorn bushes and not get a flat.Don't think the road commisioner or nieghbors would be happy with me running it up and down the road.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:46pm
My guess would be the Amish, or Mennonites had it before!
Greg Kroeker
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:48pm
Probably mennonites. Ever seen a $100,000 new john deere tractor with steel wheels? i Have.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:56pm
Amish. Plenty of them around here. Neighbors have a WD-9 McCormick, another has a 4020 JD, and I've seen a 4030 maroon belly(?) and D-19 AC all on steel wheels. Most are shop built like those are. If they were River Brothern Mennonite wheels they would be better built.
ToddBinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddBinNY Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:11pm
Amish wheels.  Most Mennonite's have rubber pads on steel, by us.  I  guarantee that dealer has been asked about selling just the wheels off of that machine.  Mennonite down the road has a JD 4455 on steel duals and a 1460 combine on metal tracks.  There is an Amish with a AC 185 on steel also.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 9:30pm
I would not want a tractor that spent it's whole life on steel. I have had Continental U's with steel and with rubber and you can't believe how hard the steel is on the old tractors. It just wears them out!  Dave.
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 10:13pm
Wheels are on ebay for 350.00 Gary IN
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:30am
He only gave 1100 for the whole tractor at auction
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 11:50am
I bet the seat bushings are worn!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:47pm
I cannot believe what I learn on this forum.   I have NEVER SEEN OR HEARD of a D-17 or any other late tractor on Steel.  Have to put this down for something new I learned today.
Yes, I have seen the Amish pulling a bailer with three horses and an engine on the bailer to run it but never have heard of putting steel on a relatively late model tractor.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 4:53pm
They also want 1400.00 for engine.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 6:39pm
I saw a late model JD in western Ky driving on the edge of the road on steel. Me and the guy with me just looked at each other like "what was that". JP
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:28pm
Here is a picture of a 200 and a 715C backhoe that I took in PA last fall. The owner is Amish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:15pm
why dont Amish use tires ???
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 10:28pm
The Amish around here use tires. See them from time to time running up and down the road in their "Amish convertibles".
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:35am
Never knew Amish to use ANY type of tractor? I always thought it was the Mennonites?? They put the steel wheels on I was told to keep the youngins from driving them to town??
JNunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JNunn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 4:53am
 Them there is what we call pilgrim tires round here
WC, WD, WD45, WD45D, WD45PS, D17, B12, Two-Ten, 185, 710, and 7010
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 5:44am
The Amish live by a set of religious beliefs that (usually) prohibit the use of gasoline powered gear rolling on rubber. I have seen horse-drawn balers with the Wisconsin engine but never a tractor, even on steel. Latter would be more likely with Mennonites whose beliefs are more liberal. Amish practices vary some from location to location as the local religious leader has considerable leeway to establish the rules in his location.
WC, CA, D14, WD45
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 5:51am
I have seen a lot of steel wheels around here with rubber cushions built in, 3-4 inch diameter and 3-4 inches thick kept in place with steel all around
Edited by JoeO(CMO) - 19 May 2010 at 6:33am
Mr.P View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mr.P Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 8:17am
WE had some on are D17 that was weilded to the rims.SO we could pack are blow sand after we plowed it then we would change the back to the rubber tires after we pack the ground.
Walt(E-IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walt(E-IA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:39pm
A friend once told me about a Mennonite neighbor of his who put steel wheels on a brand new John Deere riding mower.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 6:30am
When I worked parts at a CaseIH dealer the parts microfiche showed steel wheels for a 706 right from IH. The Amish around here (meaning 45 mile to the SE of me, there are none near by) use just horses mostly although I was at an auction that had an old Allis mounted on skids once. I think it was an A or U. That was 20 plus years ago but I don't remember what it sold for. I'm sure it went cheap. They used it to belt power a feed mill and other things. There are Hutterites 10 miles to the south of me that use all modern equipment but live on a commune. They manufacture stainless steel products.
Wink
I am a Russian Bot
richneu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote richneu Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 10:48am
Walt , I would like to see a steel wheeled lawn tractor. I bet it would not be kind to a lawn. Amazing how people rationalize their beliefs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 1:09am
rich I too have seen steel wheeled lawn mowers. They are not what you are thinking of as steel wheels. There are no steel lugs and they are covered with a hard rubber. They look almost like some skid steer hard rubber tires I've seen.
WEL(TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(TN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 5:44am
Looks like Roberts is parting out this D17. Saw engine and wheels advertized. Roberts always wants market value plus 50% for his parts. I can't imagine how he stays in business.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 6:07am
It never siezes to amaze me what the amish will come up with.  We live next to the l2nd largest settlement of them (right behind Lancaster PA) and they always "interpet" the beliefs to fit them.  No electric, but we put services into "freezer barns" that they rent out, cell phones, texting, etc.  We even have a buggy that comes by with a stereo in it blasting Lady Ga Ga.  There are a couple guys that make the steel for anything.  The largest I have seen around here is a 7600 4WD JD
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 8:07am
Their religious beliefs feel the rubber "separates" them from the earth
This page was generated in 0.057 seconds.
