WD PTO Noise
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: WD PTO Noise
    Posted: 16 May 2010 at 2:30pm
Hi all.  I told my neighbor I would get some basic advise for him for his WD PTO ailement.  I don't have a clue since I have a D 15 and the books for it.
He uses this WD (believe it or not) to power his 10 foot three blded mower for cutting grass on and round his air strip.
Anyow Tommy told me this am that the gear that drives the pto shaft has chipped teeth.  He does have another WD parts tractor in a shed.  So I am looking for some basic guidance to give him on how to get to the innerds to replace the bad gears.
Like do you split it and then what, or can you get it done from underneath.  I am assuming that it is a tranny disassembly?
So would apreciate some basic guidance on how to go about it.
Thanks all
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 2:58pm
If it was me, I'd Look at the rear PTO shaft bearing and then drain the oil and then drop the PTO box and look at the gears, bearings in there first, Then look at the drive gear in the trans.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 3:41pm
There are gears in the bottom cover. If it is one of those, drain the fluid,remove the bottom cover and replace it with the one off the parts tractor. If it is higher up, the tranny would have to come apart.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:55pm
  can be done without splitting the tractor have replace many drop pto box an give a good inpection can see all from there  all but top gear can see it if battery box is removed  if parts tractor has lube in it it will be ok  tafe off hyd. pump an do all your work thru the pump cavity  can get upper gears out of there if upper gears are bad
  for get gear count  puter at home   call 1-574-342-4545 for info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 6:59pm
  we also have the gears in stock for repair  if you are lucky maybe just top idler gear on pto box  also check the pto pin as it is a good culprit for a gear failure
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 2:46pm
I have had two 45s ptos out. Both times it was the top idler gear. weakest point. You have to split the tractor and remove pump hand clutch ect. I have done it twice , not much fun. Bush hog and age got em.
