Sprocket liners
Josh H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Topic: Sprocket liners
    Posted: 29 Jun 2016 at 6:32am
I heard pigeon products and manufacturing in garrison, north Dakota
Has them. +1 701-463-2959. Thats what I'll be doing on my machine
Although someone said some other segment will worth on 16b. He says
Make sure to time sprocket before welding liners.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 8:42am
arnt 16B's equipped with bolt on segments?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 8:44am
Why can't you use liners on segments. Cut them in half where the segments end
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 8:51am
You can.  I just thought it was kinda silly to cast liners to weld onto replaceable segments when that is why the were designed :  to bolt on new segments not have to weld on rings like the old style.  why not cast it as an oem match?
Edited by CAL(KS) - 29 Jun 2016 at 9:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2016 at 10:38am
Liners or cups can be welded in , yet if the sprocket teeth are worn heavily I would question getting them into proper position so as to contact bushing outer surface.
Seen some attempts at repairing worn sprockets and it seems more trouble that it's worth .
 I built up top surface on a set of HD5 track welding first with 7018 rod and then a hard surface rod over that - I got about 2 years of life out of the job but ended up replacing sprocket as well as track - I welded on sprocket rings onto old spokes >
 On my D6 I welded new rings onto spokes to take D5 segmented sprockets - then the rest of machine self destructed before I could get my investment back in the tracks .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 10:05pm
Whats the option besides used because i can't find new parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 5:00am
Conversion to what is available, finding a sprocket of similar diameter in a other make machine and converting the entire undercarriage to that machine series.  Idlers can be converted, roller frames re-drilled for different mountings, sprocket ring can be replaced with a different make on the old spokes.  Been done to other machines and shown on here.
I have that issue with my old 7G, it uses 7" pitch that no one else uses today, IHC did thru the Dresser machines but even they are all gone.  So I have a set of spare rails I will use up and either make the attempt to convert or give the old machine up.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 6:39am
Sprocket liners # 54 C200 for (2) sprockets for my HD6G $281.50 including shipping
Pigeon Products & Mfg
PO box 187
Garrison, ND 58540
(701) 463 2959
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 7:52am
Henderson MFG in Texas has sprockets for many brands and models.  they show for 16 and 16D but not 16B.  might  be worth a call though.  these are new rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 11:09am
Pigeon Products & Mfg has sprocket liners for HD7G for $312.50 including shipping and for HD11 for $335.50 including shipping.
