7020 hydrolic question
corlewfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Topic: 7020 hydrolic question
    Posted: 15 May 2010 at 2:22pm
lift arms are slow but you can push traction booster valve behind cab by hand and it is fast. all the outher hy is fine
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 6:28pm
you might look at your rear cab mounts to see if they are worn out. Had the same problem on our 7000 and new rubber mounts fixed it as the cab had settled and did not allow linkage to work properly.  Doyle
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 7:30pm
Since the 7010 uses a cable, the cab mounts are not the problem.
Check the cable adjustment. If not that, then look at the linkage for wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 8:35pm
I'd suspect linkage that is rusted/seized/stuck behind the cab that operates the 3 pt spool........usually happens if tractor sits outside a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 8:40pm
dont think it is the linkage cause the arms go all the way up and down they are just really slow
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 11:05pm
The linkage should push the spool just like your finger does.....so, it must not be doing that (if you can raise the hitch with good speed by pushing the spool in yourself).
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:39am
is the lift arm valve and traction booster valve the same
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 9:13am
yes
