B Engine Cylinder Head Performance
Ryan59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Topic: B Engine Cylinder Head Performance
    Posted: 13 Jun 2016 at 5:02pm
Hello gentlemen, ladies. First I would like to say that I am not pulling with my tractor, but I would like to share and ask questions about performance concerning just the model B (125ci) engine.
I removed the cylinder head off my engine, removed the valves and guides, pressure washed it and inspected it. There was substantial corrosion in the runners and valve pockets. I spent roughly six hours shaping and blending the runners and pocket areas to both remove the damage and smooth-blend below the valve seats and reduce the radii of the split intake "Y". Before doing a final smoothing/blending I took the head in to have .150 skimmed off the surface.
Looking at the factory rocker arm assy I can see room for improvement. First I measured a stock rocker to get an idea of the ratio. Center of shaft to center of valve stem 1.95 and center of shaft to center of pushrod 1.30. Divide 1.95 by 1.30 equals 1.5 ratio. This was just an "eyeball" measurement but it's what I am going to go by. " border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:07pm
" border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:09pm
" border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:11pm
This is a 1.6 roller rocker, I have some spare BB 1.73 Lunati's that may be better to work with. " border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:13pm
" border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 5:16pm
This tray was under the rocker arm assy. Seems like it would prevent oil from dripping on the lifters & camshaft...maybe?
" border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 7:27am
 The "tray" was used to keep oil away from the valve guides before stem seals were generally accepted. If you're not looking for added performance for pulling, what is the need for the trick parts, porting and taking .150" off of the surface? Many of these engines have run for many decades in factory form and most will out live many of use just as they were built.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 10:41am
Thanks Paul, I wasn't sure why that tray was used.
Shop finally called to say my cylinder head was finished. They media-blasted it first, installed the guides I supplied, installed hardened exhaust seats, cut the valve seat angles on a Serti machine. Lastly they milled the surface of the head .150.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 8:49pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 10:46am
Paul happens to be running a turbo CABig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 10:59am
This picture is a give-away to how far the head was milled.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:01am
Looks like a new head.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 8:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:04am
happen to have 2 kz 1000's sitting at dads place :)
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:04am
Two of the exhaust seats were pitted deep enough that seats had to be installed. The shop owner said to just do all the exhausts and it will be unleaded gas friendly, never have to worry about seats wearing out again.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:14am
I may retake these pictures with a different camera/lens. It's difficult to show the bowl porting. I spent a leisure 6 hours smoothing and blending the bowls to the runners. Not necessarily for performance because this engine has had water in it over a long periods of time. The piston domes of 1 and 2 are extremely bad and all of the sleeves will note hone out (pitting) Anyway I basically blended all the exhaust bowls and runners to match. I did a little at a time. After I removed so much on the 1st bad port, I would move to the next and so on until they were all equal (feeling with my calibrated index finger).
" border="">
Edited by Ryan59 - 23 Jun 2016 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:15am
This belt-drive magneto would work with any 4-cylinder or V8 engine. Make a bracket to hold it in place and go.
" border="">
Edited by Ryan59 - 16 Jun 2016 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 11:30am
my dad bought one new in 78 and still has it.  bout 17k miles on it now.  he got another one a couple of years ago so one of us boys could ride with him.  its usually my brother who has no kids
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 2:55pm
Before pressure washing this head it needs a little clean-up porting with sand-paper rolls. More or less to radius sharp edges, nothing real important.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 9:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 2:58pm
Hard to focus on the inside of these bowls to show how conservative I ported these.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 3:01pm
One thing I did "open up" was the "Y" split area where the intake runners divide. I decided not to build-up the back-side wall of this split port with epoxy as described by a knowledgeable and highly respected person on this forum. I had to remind myself that I'm not going for the level of performance that his engine is built.
" border="">
Edited by Ryan59 - 23 Jun 2016 at 9:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 3:03pm
I can make this conversion plate relatively easy but as some of you may already know the push-rod holes would need to be off-set. Before I get to far along could one of the modification oriented person's step in and advise.
" border="">
Edited by Ryan59 - 24 Jun 2016 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 3:06pm
I bought these 1.73, 7/16 stud Lunati's 19 years ago and would like to attempt to use them if at all possible. From the center of the push-rod to the center of the valve stem roller that are 1" shorter in length that the stock stamped steel & spot welded arms.
" border="">
Edited by Ryan59 - 24 Jun 2016 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 3:17pm
I can drill and tap these Lunati's for the adjustment screw.
" border="">
Edited by Ryan59 - 24 Jun 2016 at 9:25pm
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 7:15pm
what is that distributor off of
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 9:09pm
With a blue cap? It's a Vertex magneto. It's off a Kawasaki KZ1000 drag bike.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 11:05pm
Apparently this topic has become "look at my foreign motorbikes" instead of "B cylinder head performance"
www.awtractor.com
A&W TRACTOR 920-598-1287
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 11:12am
  SO???!!!  Performance is bilingual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 2:53pm
If you are thinking the pictures are taking up band width you are wrong. They are simply linked to my photobucket account. They can go away as quickly as they appeared.
As my cylinder head work progresses I will clear the motorcycle pics. Parts should have arrived Monday but YT said they are behind getting orders out. Head has been in the shop waiting.....
This was my daily rider, 2010 FXDWG bought new. Had to sell when I retired.
" border="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 3:04pm
That magneto would work on any 4-cylinder and V8 engines as well. Vertex makes a cap for dual-plug 4-cylinder heads. On a V8 the second wire would connect to a cylinder on the exhaust stroke. So 1-4-6-7 fire on the compression stroke and 8-3-5-2 fir on the exhaust stroke for that 720 degrees. Crank trigger ignitions use (or can use) 4 coils with dual plug wires coming out. As far as the crank trigger is concerned it's bolted to a 4-cylinder engine.
This is the kind of information that is universal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 4:39pm
it looked like it could be used on my pulling tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2016 at 6:35pm
And it would. If you had a front engine plate, it could mount on there backwards so the cap faces the engine & wires would be where they should be. The belt would be in front and be driven off the crank. The governor would still control the carburetor arm. Just put a block-off plate on the back side to keep oil in.
Looking at the mag off this tractor it doesn't have any advance/retard either so this wouldn't be any different. Set it at what? 20 degrees crankshaft? For stock governor.
