WD 45 Wide Front Value
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Wide Front Value
    Posted: 01 Jun 2016 at 12:04pm
What sort of price is a WD45 wide front bringing these days?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 2:25pm
It's very hard to say without more info. Is it all original or restored. How is the sheet metal? How much wear on the pedals? Does the engine run smooth with no smoke? Do the PTO and hydraulics work as they should?
Assuming an original, good running tractor with decent rubber, good rear rims and everything in order, my guess would be somewhere between $1400 and $1800 in our area.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 2:29pm
I was thinking that he might be talking about just the WD45 wide front end itself...maybe?
Rick
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 3:49pm
Rick
I was thinking the same thing.
If that's the case, a low wear 4 bolt will bring $250 easy. A three bolt will (if not beat up) will be much less.
That would be prices minus tires in my area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 3:59pm
Just the front end not the whole tractor
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 4:15pm
$500 I looked for two years and could not find a complete one for less. So I bought a complete running wd45 for $800. Drove it on the trailer and brought it home it was in way better shape than the one I was restoring.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 4:41pm
I sell the three bolt wide front for 400.00 and the four bolt wide front for 450-500.00 all the time. These are pretty decent wide fronts though.   Rick
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 12:29am
I sell 3 bolt for $350 and 4 bolt for $400 in good shape. anything over $500 would be paying an arm and a leg.
www.awtractor.com
A&W TRACTOR 920-598-1287
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 2:48am
Not if you put several new parts in them, Alex. It wouldn't be hard at all to have in excess of 7-800.00 in one, if you bought one and went through it and replaced worn out things. Been there, done that.  Rick
This page was generated in 0.073 seconds.
