Advice on removal of front bolster - WD45
Hlone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Topic: Advice on removal of front bolster - WD45
    Posted: 11 May 2010 at 10:29pm
Any tips on getting the front bolster / axel housing out of.  I have detached the steering knuckle and support and the 8 polts holding the it in place on the front.  I have supported the frame and have a cherry picker over it to support it.
So far after prying, hammering, and talking nice to it I have managed 1/8" forward progress out from between the frame.
Tips / Osage advice appreciated.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 11:31pm
block drivetrain good and spread frame more(left side), pb blaster
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 6:18am
I agree.  Make a good solid frame support, soak each side with kroil and take a hardwood block or a piece of steel and try wedging the two rails apart, and then working it out.   Remember, it probably hasn't moved in close to 60 years, so it's not gonna come out easy.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 6:32am
You may even want to loosen ALL of the frame bolts on one side to let the frame move a little easier. You don't have to remove the frame rail, just loosen the bolts a quarter inch or so. I use the biggest cold chisel that I have to wedge into the little gap between the frame and bolster to break it loose.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:31am
Loosen bolts on the left side. If you loosen right side the oil from belt pulley housing will spill out.  HTH MARK L
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:36am
Good point Mark
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:41am
i took the tractor and tied it to a tree from behind and put a cumalong omn the front with a strap to my pickup truck and spread the frame a little and it came out hard at first but then it not to bad dudley
a member of hendricks county antique tractor and machinery association club.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:53am
Don't forget to losen 1 side of the motor mount. it's a angle iron piec than contets the frams to the front of the motor.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 11:37am
You might need to remove the lower two radiator bolts too. and now look at the radiator for leaks too.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:20pm
Thanks for the Advice.
I already pulled the radiator (one nut on the botom broke loose and ended up having to cut the bolt to get it off)
We ended up loosening up bolts on one side, and used some wood blocks to spread the frame open to give it some wiggle room.
We needed to pull the front bolster to take out a shim to tighten up the steering.
Now that I have everything uncovered I noticed that the exhaust manifold was missing a gasket on one side and had rusted some there :(  We got the nuts off without breaking any of the studs, but ended up breaking 2 of them trying to get them out.  One of the 2 was 50% out before giving up and the other gave 1 turn before breaking off.
Now I need to get an exhaust manifold, studs, and gaskets to fix things right.
As always an adventure when fixing one thing and finding something else!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 4:27pm
Couldn't agree more about the adventure part of rehabbing these old tractors! I am waiting for a used manifold for my WD45 to arrive. Sprayed the nuts (all appear to be brass) with solvent a couple of days in a row - all but one are willing to turn as I write this. I consider myself pretty lucky! Good luck with your manifold replacement.
WC, CA, D14, WD45
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 7:56pm
i have removed several of those nose steering boxes.the best way is to loosen ALL of the side rail bolts about 1/4 in.loosen the front engine mount.take a pry bar and spread the frame rails this is a good time to hit the area between the rails and the box with a pressure washer.it will slide right out..i meant to say remove the front engine mount.(dont loose the shim pak)
