HD11 tracks too tight?
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: HD11 tracks too tight?
    Posted: 07 May 2016 at 11:21am
Just wondering if these tracks are too tight. Seems every dozer I've seen had a little bit of slack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 1:16pm
Need a little droop in them or they wear faster.Those are too tight in my opinion.
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 1:52pm
Hard telling without the tractor moving; it may have been backed into there and all the slack is on the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 11:07pm
Thanks. I know there's a specification on the amount of slack but, a trained eye can do just as well sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 5:28am
Also, check the number of links in the track. a common "farmer fix" is to cut a link out of a too loose track.  You need to count the # of links, find the specification, and check.  If a link is cut out, count on a new set of chains, and possibly a lot else worn out...
