WD starter switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: WD starter switch
    Posted: 04 May 2016 at 9:19pm
I got a question on my WD starter switch. It is new on a newly rebuilt starter. The problem is that as I tighten up the nut that holds the battery cable on, the switch is turning inside. Do you just take the two screws off and pull the starter switch off, then turn the nut so it turns the switch so it is right...then put it back on with the two screws ? Is that how you get it tight and make sure the starter switch is positioned right?
Thanks!
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 9:23pm
I think there should be 2 nuts on the post. One should be tight and pull the post into position on the housing, then you connect the cable and tighten the top one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 9:25pm
Well, not by the pictures I see online, maybe you got a bum imitation switch?
Some have 2 nuts.
http://thumbs4.ebaystatic.com/d/l225/m/mivGDc0Xx2e1wRbXsrw2bhw.jpg
Edited by CTuckerNWIL - 04 May 2016 at 9:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 9:25pm
Oh...well it only came with one! I will have to take it off and redo it!
Thanks Charlie!! I am learning!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2016 at 9:51pm
Some have 2 nuts.
Thanks Charlie...mine came from the guy who prof rebuilds starters in Cedar Rapids. He put it on. Said it was a good one! I will have to ck it out!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 6:35am
probably expected you to keep the nut off the old one....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 6:51am
You might have to find a couple "jam nuts" if yours is too thick to allow a second nut. Jam nuts are about half the thickness of a regular nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 6:52am
Yes you will need the second nut to tighten up on the cable.
Sounds like your making progress! We need some pictures too!:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 7:00am
Mike,
If you need new nuts I'll shoot a couple out to ya. Now there's a loaded question!! LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 7:41am
Are they the "short" ones Steve  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:15am
You guys are funny! I will ck to see if I have some thinner jam nuts...
Thanks for all the help. You guys are great help. I always get good suggestions on this forum
Mike
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:40am
They should be brass nuts, not steel in that application.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:55am
Mike, I think you should take the switch off to make sure the contact is setting square with the movable contact when the bottom nut is tight. It wouldn't hurt to make sure the stud and contact are insulated from the housing once you have it tight. An easy check if you have a test light or ohm meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:11pm
Thanks Gerald and Charlie! You guys are great to have to help!
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 8:12pm
Mike,
Steve@B&B
Steve when I can get to it I will ck to see what I have. If I need some I will let you know! Thanks buddy.
Mike
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 9:03pm
If the 2 insulators are in place the bolt can't turn much. Without the insulators you will have fireworks. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 6:44pm
I took the switch off, got it lined up and she started right up! Thanks for the help guys.
Mike
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 10:02pm
  Thumbs Up Thumbs Up
