WD45 - Oil in Clutch Housing
Hlone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Topic: WD45 - Oil in Clutch Housing
    Posted: 10 May 2010 at 10:19pm
I have a 1953 WD45 and need to add oil to gears in clutch housing and can't find what type to use in it?  I didn't find a reference in my service manual for this one.
The Fill plug is in front of the clutch plate area and is NOT the same fill plug for the transmission or the Hydrolics. Any help is appreciated!
Edited by Hlone - 11 May 2010 at 5:53am
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 7:01am
The "clutch plate area" [ engine main clutch assy] is a "DRY" compartment. Look your ser. man over again, if it is adecent one it will instruct on fluid levels/compartments,etc.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:20am
Here is a picture that shows the three fill holes.  As was mentioned, the engine clutch housing - orange in this picture is dry.  The frontmost fill hole is for the hydraulics.  The rear two fill a common area that has no seals separating it, there are bearings for the oil to flow through so it may be easier having two fill holes.  You can use Hy-Tran fluid for both the hydraulics and transmission/rearend that makes it easy.  HTH Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:24am
To be more correct not all the orange section of this picture is dry, the compartment directly in front of the torque tube gets hydraulic compartment oil flowing in it to lube the belt drive gear.  There is no place to add oil there though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:28am
Tom, See you have some Amzoil sitting there, Good product!, Great pic's as usual, Chris/CT PS. How's the Industrial/Schuttle coming along?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:37am
I wish I could say I had some progress to report but things have been busy and I haven't done too much on it yet.  I took the rims off my parts tractor and have them off to the powdercoater.  I plan on using them on the WD45 Diesel though.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 9:29am
Tom great pic as usuall, better than op manual, I hear you may not be able to make the carravan this summer , bummer Mark L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 9:58pm
Thanks all.  The Middle compartment is the one I was talking about where the hand clutch is.
Great picture to help out!
