8070 hydraulic problem |
Post Reply |
Dwayne TX
Silver Level Joined: 11 Sep 2009 Location: Texas Points: 221 |
Posted: 10 May 2010 at 2:23pm |
The line that runs from the pump at the cab firewall to the fluid cooler rubbed through. I lost about 3 gallons of fluid before I got it shut down. Replaced the line and refilled the fluid. Now, with the 3-pt arms raised, the power steering gets 'jumpy' then almost non-existent. Lower the arms and it goes back to normal. |
kip in cny
Orange Level Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
sounds like air.
160 CA 920diesel 5020 HD-3
skipwelte
Orange Level Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Did ya put the oil in the trans or rear end? Power steering is off the gear pump and that gets oil from the trans. The tube at the back of rear end housing below the cab window is the trans dipstick and fill tube. It does sound like air. Air will work its way out fairly quickly, Id double check the oil level. HTH |
Dwayne TX
Refilled the trans on the upper LH side (long tube w/dipstick) not the one above the top link w/o dipstick.
I've run it off and on for about 30 minutes, working the steering and lift, then checking the fluid. It's staying at the same level now.
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20938 |
WRONG......Fill the rearend and check the sight glasses.............must be ten gallons or more low on oil.
Dwayne TX
Sight glasses never showed oil to be low.
DrAllis
Remove the top sight glass by unscrewing it.(they get foggy).........the oil you lost is from the orbitrol??..which is rearend oil. |
Gregor
Silver Level Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
By chance, you didn't change out the hydraulic filters too. I once forgot to put the pusher on the end of the filter and hand no or very little power steering. |
Post Reply | |
