air filters UPDATE
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: air filters UPDATE
    Posted: 27 Apr 2016 at 9:58am
Looking to purchase a conical air filter for my puller tractor to cut out the extra weight.  Looking at running it right off the carb but my choices are prettly limited with the inlet size.   I see some tractors run a tube and then adapt to a larger filter, does this help or is it still limited by the inlet size of the carb.  currently theoritical figured about 100 cfm at max rpm but may got up to 140 + later with engine build.
Looking at universal filters but nothing shows cfm ratings.  Looking on a 6 X 4.25 cone with 2 inch inlet.  is this big enough?
dry, oiled?  suggestions?
thanks
Edited by CAL(KS) - 12 May 2016 at 8:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2016 at 10:02am
this is what i id like to do
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2016 at 1:36pm
I would not run a filter right on the carb. I would run a piece of pvc pipe back towards the transmission then a filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2016 at 2:19pm
not really practical on a UC as the steering shaft is in the way.  Ideally a nice looking piece of pipe would run up through the hood but i dont have access to a mandrel bender.  just really need something setup to get going,  i  have a stock motor right now anyway.
Edited by CAL(KS) - 27 Apr 2016 at 2:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2016 at 8:18pm
I didn't look at the picture sorry. I see that wouldn't work for your application but With a filter straight on the carb it pulls air in from all directions and tumbles around and doesn't flow well. I was told this along time ago and didn't believe it till I hooked it to my dyno it made four hp more on both my WCs with a 24" piece of pvc.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 5:59am
to get the turbulence to stop in a pipe you need a straight run of pipe you take the ID and make it 12" for every 1" so a 2" pipe needs to be 24"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 6:28am
Thanks guys, I did not know this. I'Ll get something figured out, I will need all the help I can get.
Will a bend in the tube affect the air flow negatively after the straight run? Thinking I need to get a tube up through the hood for a 24 inch run and avoid radiator heat.
Edited by CAL(KS) - 28 Apr 2016 at 6:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 8:06am
I wouldn't worry about that bend to much. It would have to be better then sucking in that engine/radiator heat.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 8:17am
What are you guys running for air filters at the end of the bent pipe?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:43am
I have a Spectra Cone shape on mine
They are around $30 at local auto shops.
3" hole diameter seems to be standard
Charlie
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 5:53pm
 Cal(KS), theres some Minnie Mos in my area that just run the tube forward just in front of the rad. Doesn,t  look the best but it works for them. Wouldn't be hard to do on a UC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 7:27pm
I know these are for a motorcycle. Do you think they would allow enough air flow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 8:38am
here is what i have concocted.   couple of mandrel bends from summit racing cut and welded together because naturally 1 piece isnt long enough.  just need to weld on a ring so it can bolt on at the manifold.  i have a 24 inch run before it hits the elbow
only about 50 lbs lighter than that cast tank of an air cleaner lol
thanks for all the input guys
Edited by CAL(KS) - 12 May 2016 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 8:46am
Perfect
Charlie
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 9:50pm
Not an AC but you can see where mine is..
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:40am
that is a nice looking tractor.   I wish I had the time or could afford to paint mine but i will be lucky to get this thing legal to pull in time.   but .... paint doesnt make it pull any better :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 8:12am
How much does a UC weigh?
For a 318 engine, they don't seem to be very powerful. I guess it had a lot of Torque?
Edited by Charlie175 - 13 May 2016 at 8:36am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 11:27am
charlie, im hoping to get down to 5000 Natpa Div II legal but i i wont know till im done and weigh it.
I hope it has some torque because no, they arnt rated very high.  I have only had mine running for a few minutes after i bought it before i started to strip it down and work on the finals/leaks/ brakes.  They only have like 4-1 compression but I have some ideas on getting alot more out of this motor, however Im going to hold off until i get some pulls in and see how it goes before I spend my very limited income.
coincidently  MM  U variations start showing up at #5500 in the natpa results
according to tractor data they spec closesly stock wise to AC U @ 36 hp pto and 27 Dbr
U is 35 and 30 respectively
to clarify, I dont have the resources or intentions to compete on the NATPA circuit, my local club uses natpa rules
Edited by CAL(KS) - 13 May 2016 at 11:40am
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 8:14pm
In the early 1970's I had a friend that pulled a turboed UC in the 5500 Super Stock class in SE Kansas....I will see him tomorrow at a pull..
UC AC's are few and far between in my area..In 1976 I bought one in rough shape and sold it to a friend..He restored it and then about 10 years ago sold it to another friend..It now resides 8 miles east of me..
Your UC AC looks pretty nice..You seldom ever see one at a pull because they are scarce..I think one could be made to be a good 3 MPH puller..
Theres a huge cubic inch U MM at Fredonia,KS and I think he pulls either 4th gear or road gear in the 5000-5500 Open classes...At this pull he's coming down the track over 15 MPH...I can run 3rd gear in the 5500 Open but seldom pull that class...I'm 300 cubes less than this one and its going to get bigger..My U MM is a 4-5 MPH puller at 5500-6000-6500...
Edited by 180Puller - 13 May 2016 at 9:32pm
