1942 HD-3 |
larslog
Topic: 1942 HD-3Posted: 16 Apr 2016 at 12:00am |
Looking for rollers and front idlers for a 1942 HD-3.
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Posted: 16 Apr 2016 at 7:28am |
If you don't find any close to you there a minonite family called Zimmermans in versailes Missouri. Has a big salvage yard of dozers. etc. DO A SEARCH on the net. He does ship. Not cheap but they seem to know what there talking about. norm
ac_sd
Posted: 16 Apr 2016 at 3:25pm |
I'm pretty sure the 1942 HD-3 used the same undercarriage as the Model M and should be fairly easily obtained !! Good luck with Your Rare Crawler !!!
larslog
Posted: 18 Apr 2016 at 12:22am |
ac_sd
Posted: 18 Apr 2016 at 3:47pm |
AC did not build very many, and parts sadly will reflect that... What You have looks great... Good luck on it..
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 18 Apr 2016 at 7:42pm |
Is it possible that HD5 parts would interchange? Hope you can find parts you need, as that rare crawler needs to have new life breathed into it. It sure looks good so far. Good Luck! Darrel
donoman
Joined: 18 Feb 2015 Location: New Zealand Points: 117 |
Posted: 18 Apr 2016 at 8:53pm |
donoman
Posted: 18 Apr 2016 at 8:55pm |
how does the track pitch compare with HD5/6?
darrel in ND
Posted: 19 Apr 2016 at 7:27am |
There is a place in Idaho called general gear that has lots of crawler parts. I'd sure try them. If you can't find a number for them by go ogling it, let me know, and I'll get it for you. Darrel
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 19 Apr 2016 at 10:00am |
Is the powertrain pictured all that you have? I sure hope you can find what you need.You might call Tony Carbaugh. His contact info is listed here on the site.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 19 Apr 2016 at 12:37pm |
Very neat indeed! I wonder how many of them are accounted for? It's disturbing when a scrapper comes in and simply takes "junk" to the scrap yard. There's a good chance the parts needed were in that pile! Having the pieces, even if worn out, can be repaired/saved, but not having any of it will definitely make it a challenge! Thanks for sharing!
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 19 Apr 2016 at 9:33pm |
+1 on General Gear! They supplied me with a brand new pressure plate for my HD5B. They have several machines they are parting out. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
