need a 3pt bolt size
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: need a 3pt bolt size
    Posted: 01 Apr 2016 at 7:10am
Does anybody know what size bolt goes into the 3 pt bracket that you see in this ebay posting?  I'm throwing a 3pt on my 2nd 616 and did not receive those bolts.  Would those bolts already be in my non 3pt unit?
Thanks
David
http://www.ebay.com/itm/Allis-Chalmers-616-620-720-Simplicity-4040-4041-9020-Three-Point-Lift-Arm-/222069303294?hash=item33b45ca7fe:g:iDsAAOSwI3RW-1bY
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:54am
I'm sure I could tell you but can't openposting
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:09am
There are 2 brackets, 1 for each lower link the bolts to the tractor and a pin goes through them for the lower links to pivot off of.  I'm need the info on the 2 bolts that go through each of the brackets.
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:25am
1/2"-13 x 2" Hex Cap Screw per the parts book. (2) per side. I would use grade 8.
Edited by mnoonan-NEWI - 01 Apr 2016 at 10:27am
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 12:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 12:37pm
Thanks!
