185 frame supposed to have threaded holes?
Daniel Christensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Topic: 185 frame supposed to have threaded holes?
    Posted: 07 May 2010 at 11:15pm
On the frame of my 185 by the engine it looks like the bolt holes have been painted such that the insides of the holes are smooth. Too smoothe to just be one layer of paint filling in the threads. I know these holes are threaded on most Allis Chalmers because we mount stone boxes on them just by taking an every day bolt and threading it in. I want to build stone boxes for my 185 and Ultimate Drag, and it's not like it would slow me down obviously, but I was just wondering if they are supposed to be threaded holes or not. I'm pretty sure they are and they're just painted over, but there is not even a sign of threads.
CAx3, Bx2, G, D17x2, D14x2, D15, D19, 190XT, WC, WD-45, 185, Gleaner K.
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 5:56am
No the holes in the frame rails are not threaded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:43am
  I have never seen an Allis with threaded holes in a frame rail. The front bolster, between the frame rails on the W series tractors is threaded.
  Threads should be a minimum of 1 1/2 times the bolt diameter deep and a frame rail isn't thick enough to have that many threads.
Edited by CTuckerNWIL - 08 May 2010 at 6:45am
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:54am
D14 and D15's had the threaded holes.
I am not sure if the D17's have or have not, will check today on my D17.
-not sure if the 170's have or not have and my 185 does not have
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:07am
Oh, then must be we threaded the holes on our D17's. Come to think of it, the D19 stone box doesn't use the frame rail holes at all. It uses "hangers" that go around the hole top of the frame rails, almost like a hand clamped to the frame. See:
BUT, the D17 stone box here is def threaded into the frame, so is the snowplow we made for it. Believe me there there are no nuts on the other side of those bolts. Simply threaded right in to the frame; it's nice and convenient.
And our D14 which we also made a snow plow for; threaded:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:15am
D17's have threaded holes in the side frames.  I clearly remember that to mount the front cultivator and the cornpicker.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:27am
It wouldn't be hard to tap out the holes that are there in you 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:34am
Daniel, the little tyke there looks ready to defend HIS D17,  no one dare to come near!
Edited by JoeO(CMO) - 08 May 2010 at 7:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 8:06am
I knew it. Look at the front hole in the D14 where the snow plow is mounted, if it wasn't threaded there's NO WAY you could get a nut or let alone a wrench back there lol.
No way you could get on that one from the back!
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 8:48am
My D17 IV has threaded holes on the rail.  Clearly remember, as one had a broken bolt in it that had to be removed and rethreaded before I could put the loader bracket on.
