1958 D17 NFE (lots of pictures)
 Post Reply Post Reply Page  123 14>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: 1958 D17 NFE (lots of pictures)
    Posted: 25 Mar 2016 at 6:20pm
Local sale tomorrow has a D17 for sale. I did not hear tractor run. From what I can see:
-Gas engine.
-all gauges in place.
-steering wheel intack
-Rear rubber fair to good.
-Front rubber poor.
-Narrow front end.
-PD moved back and forth. (I am not a good judge of those).
-Brakes had 1/2 pedal.
-Snap coupler system
-sheet metal looked pretty good. Minor dents
-Grill had a tear in it.
-muffler was not covered. (this may not indicate anything)
-oil in rear end was light brown and very thick
-looks like original paint.
-Fenders had minor damage.
Any ideas what this D17 tractor may bring or its current value ?????
Sorry no pictures. Not sure if I will go to the sale. If I do I will let you know. I don't need another tractor!
Edited by Sugarmaker - 30 Mar 2016 at 9:22am
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 6:35pm
Chris would you get a chance to drive it? To check the power direct the first thing is it should want to snap out of you hand as it passes the engagement point. I think of it as going over center and popping as a result of that if they go softly into gear with very little effort they clutches are probably weak. The second test is a hill and touch the breaks. If the clutch is really bad a decent hill in reverse will point it right up bad clutches won't back up much of a grade.
The d17 happens to be my fab tractor if I could afford to bring another one home I would without a second thought.
As to the value if it starts and runs doesn't jump out of gear in the transmission and the power direct clutch is good I would say it should bring 2500 to 3500. Probably be on the low side if it was here simply because no one seems to want to buy anything.   For a reference point a friend of mine bought a really nice farmall M last summer at an auction for 800. He said it was the only bid and as it ran perfect and had new tires he just couldn't bid lower. It was an estate sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 7:39pm
Dan,
 Thanks! I wont get a chance to drive it. May hear it run.
Your values sound about right. We will see.
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 6:15am
Go get it Chris. You NEED another project! Those WDs are all looking great & getting to easy for you to fix up. LOL
Good luck!
Ray W.
Get it cheap. You know how much fixing up can cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 7:30am
Ray,
 Yea that's a double edged sword alright. You pay to much to begin with and then dump money in them to fix them up. I hear you! I may go just to see where it sells at. Will report later tonight.
Outward appearance it looks like a tractor kept inside and not abused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 7:53am
Chris i think the most important part for you is to know your local market. Around here the odds of finding a d17 for sale are not very good. But I see posting in here all the time about people buying them in other places. If nothing else going to the auction and just learning how much intrest there is in it would be worth something in itself.
The one thing I will say is that my d17 is a serries 1 and it hasn't had a gentle life. It has been run on loads way too big for it I am as guilty of that as anyone. And my late uncle and grandfather where not big of fixing things they viewed equipment as something you used as long as you could and then you replaced it with something newer and better. But given that there are only two old tractors here. The farmall H that grampa bought new in 50 and just didn't have any trade in value by the time he had the number of tractors he wanted and the d17.   The H is a major project really is scrap but I will fix it someday just because of the history.   The d17 on the other hand is here because it was just too good to trade. To me that said alot. We had 3 big 100 hp tractors when I was a kid and yet that d17 was used every chance we got.
So if you can get it for a good price she will treat you right even if she does need a little TLC.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 7:56am
The narrow front end will keep a lot of bidders away. My guess is you'll buy this for under $1500, unless they have a bidding ringer planted in the auction.
The uncovered muffler might be worth looking at too, make sure the motor isn't full of rain water.
Edited by Play Farmer - 26 Mar 2016 at 7:58am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 8:03am
Isn't a NF D17 rare though? Why are so many people turned away by NFs I wonder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 8:06am
You both have good points about the narrow front end. But too many people have flipped or heard stories about tractors flipped over. My grandfather always told me be careful with the H she has been on her side on level ground. Too many people not using good judgment if you ask me.
Edited by Dan73 - 26 Mar 2016 at 8:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 8:54am
Chris must be too busy picking it up to tell us about the auction........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 9:02am
I will admit I grew up green. When I was looking for my first tractor it was between a JD 3010 NFE or my D17. Having grown up green I was leaning hard towards the 3010 but the NFE wasn't something I could get past. I use my tractor on some side slopes and a NFE was a disaster waiting to happen.
Obviously I went with the D17 and have never had even a second of regret.
If you live on flat ground or are looking for a show tractor then sure, nothing wrong with a NFE. If you plan to use it the NFE would sure keep me out of the bidding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 9:11am
I didn't think the NF made much difference, as far as flipping, on a hill side, unless you're going down hill diagonally.
I had a guy tell me once that 2 guys could tip a NF WD over just by pulling/pushing on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 9:24am
It is all about how you drive it. If you use common since they are very stable and turn much shorter. But alot of people just don't think. I drove the H here tedding on some nasty hills and never felt unsafe but you have to think before you drive it off over the hill try to go straight and don't just follow the side of a nasty hill. But if you don't think about that you can get a wide front end in just as much trouble.   I know a few times the H here flipped because people thought they could turn it short at high speed. Then they complained that the tractor was unsafe. Well only because a wide front end simply wouldn't let them turn that short. I have given this alot of thought because of my h thought about finding a wide front end but decided against it.
What I never understood was why a narrow front was ever built. Everyone always said it was for row crops but I don't get how a 3rd wheels track helps that out. Seems to me if the front wheels track with the rear wheels you only have two chances to run things over if the fronts of set in the middle you get 3 chances to run your crops over thus it seems harder but that is just me. I never did row cropping so I don't know.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 9:29am
Narrow front allows for front mounting a picker, made front mount cultivators and planters easier, and takes up less space in a barn.  I'm not real sure why the NF was first, though.  It was several years, maybe decades before mounted pickers came to be.  When you turn on headlands and end rows, the front wheels don't track with the rears anyway.
AaronSEIA
carl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 10:04am
The NF's were for row crops, the earlier wide fronts had low axles so couldn't use them for corn and beans once they were up above the height of the axle.  That changed when the manufacturers started to use the spindles by the wheels and moved the axle up toward the top of the tire.  The idea that the tricycle tractors were so unsafe has really caught on lately, the only time they were unsafe was with loaders with a loaded bucket up on side hills or turning too sharp.  The other situation where one had to be careful was in mowing road ditches, but wide fronts could be tipped in those conditions as well.  Narrow fronts were much more maneuverable in turning at the end rows when cultivating.  And of course they were a little cheaper to manufacture.
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 11:57am
I agree that the narrow fronts were not dangerous.   My dad had nothing but. Yes you had to be more careful but he liked the versatility it offered.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 2:38pm
Chris, Good talking to you today, I hope the D17 you got today is a good one. Please post some shots of the tractor after she comes to her new home and don't tell the wife it there.lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 3:50pm
I TOLD JA HE WAS Just to busy picking it up to respond.......
Now Chris,........WHERE ARE THE PICS???  We know you're good at posting pics!!  Let's see that tractor!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 5:38pm
I wish somebody in the market around here agreed with your pricing. I have a Black Bar, 1960 D17 with a very strong engine, rebuilt ps, good power director and stays in all gears and can't seem to find a buyer at the low end of this. narrow front with new tires, and really decent tin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 7:00pm
So what did it bring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 9:32pm
Folks,
Don is right I did add a tractor to the fleet. Good talking to you Don, thanks for the support and things to look for.
Probably not the best move I have ever made?
Did I need another tractor? NO!
But must have had my hand up one to many times. This was a fairly large consignment auction for our area. I got to visit with all the friends and neighbors and get a hot sausage. This little D17 sat there and was one of the last items sold for the day. I had time to look it over pretty good. Guess I liked what I saw. I had set my walk away based on the prices listed in this thread. Thanks guys that helped!
Pictures coming! Hold tight! Trying to get them down loaded. I will need some guidance on this one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 10:18pm
Guys, here are some random shots of the D17.
Allis-Chalmers D17 as found at auction 3-26-16
I started to notice things like the drawbar hole. Not much wear.
Right fender has some wrinkles.
Brakes were not sloppy or loose and they do work.
zenith carb
Manifold looked to be intact
Foot clutch pivot was worn some.
Small hangnail on tire.
About this time things took a turn for the worse and I became the owner.:)
This is a shot of a friend Dave B that helped spot me on to the trailer I just bought a few days ago. Thanks Dave!
As new owner maybe I need to do something special. I just stood next to it!
Ride home was uneventful but the Ford knew there was something back there!
Ready to unload. and check it out.
Just some different shots.
lights?
Had about 3 inches of old bolts and dirt in the tool box.
Clutch is a little loose and what is supposed to be on the choke rod for a handle?
under belly
Ok guys give me the low down on 17's!
HAPPY EASTER!
Forgot to tell you! As I was driving home to get the trailer, I was thinking about that spinner knob on the steering wheel.
When I fired the old girl up and turned the wheel, low and behold I have power steering! That made me happy too!
It seems to have a little bit of a engine miss. May just be old stale gas? Or needs a tune up, or some work?
All systems seem to function in my early trials.
This tractor has not been abused much in its life. Original paint I believe.
When I climbed into the seat and looked down the tranny lid casting number ended in "826" My wife's birthdate. The address number on the building had 826 numbers in it. I thought this was a sign!:)
Wife thought the D17 looked like crap. I Guess beauty is in the eye of the beholder!
Thanks for the support guys!
What do you think of my new to me tractor hauler! 8k GVW car hauler style. (didn't know I was going to press it into action so soon) Haven't got the center ramp built yet.
Edited by Sugarmaker - 18 Apr 2016 at 2:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 10:54pm
Chris you got a nice early d17 there very much like mine. A couple of things I notice right away. One you have the covers under the gas tank those got lost really quickly on mine I never remember seeing them on it as a kid. Shows someone really cared about it to put them back they look like a pain if you have breakdowns. Second the hood latches seem to be there and in good shape another sign someone took care of it. Mine has the bent corners of the hood bottoms from sitting them against the rear tires and having them fall over. Then there is the big one not only do those look time the original fenders but the ribs in the fenders are all solid not rusted out like most of them.
That is one nice looking tractor.   Now the not so good that carb really needs to go. It is the aftermarket modern replacement carb. I have one here it is really too small for that tractor and won't flow enough fuel. Trust me on this one I have fought this battle with mine. Call Steve at B & B. I know he has one I almost bout it a little while back but a friend had the right carb here that just need a little TLC.
Oh and you are missing the snap coupler hooks. I bet someone put a 3 point hitch on it once and removed it. That is how mine got taken off. I got lucky my grandfather knew where he put them decades earlier and they where still right into the corner of the barm. But you don't need them unless you have snap coupler stuff which I don't. I just think the old hooks look cool.
I would change the carb before I even worried about the skip the skip is probably electrical but the carb will cause more problems and the tractor will not have the power it should when the governor opens up. As I said I have made that mistake and can tell it I'd the smaller new model replacement same as I have sitting here in my scrap pile.
All in all it is really nice and don't listen to the wife it looks great I wouldn't dream of changing how it looks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 11:00pm
Oh Chris that choke rod had a black bakealight know on it at one point in time. My new carb is cable operated probably came off a much newer tractor which is funny because my buddy found it on an old wd. Anyway i will look but I think I lost that knob.
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 5:05am
I disagree on the carb. Look at the paint on it. It matches the rest of the tractor. That carb is original equipment and came on that tractor new. We have a series I D-17 that is all original and it has the same zenith on it as his does. We also have a series II that has a marvel shebler on it and the series I will do the same amount of work on a 1/3 less fuel than the series II. Give that carb a good cleaning and it will be fine. HTH.  Don Jr.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 5:46am
Nice looking tractor Chris. The rear tires look real good, that's a big plus. What is the rod that is bolted to the power director handle for. My D14 doesn't have that. Tim
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 6:45am
Very nice looking tractor, I like how clean it is underneath. I don't see a guard on the power director handle thumb button making it a early D17. For safety never dismount the tractor on the right side when tractor is running, been a few deaths on those early ones when operator left transmission in gear and PD in neutral then jumped off tractor on right side catching PD lever with clothing and moving lever forward causing tractor to lerch forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 6:53am
It looks like that rod Tim is talking about is a plow stopper. Find a good solid rock plowing and the rod kicks the power director into to neutral. Nice straight tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 6:59am
That looks nice, straight too for the most part.
What's next for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 7:29am
Congratulations Chris!!!!! Looks like you got a good one. This is good for me too. Because I have a D17 to fix up & I know what a good job you do on fixing & documenting your work. So I & others will benefit!!
Ray W.
This page was generated in 0.107 seconds.
