220 pto hollow shaft |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 991 |
Topic: 220 pto hollow shaftPosted: 10 Mar 2016 at 6:50pm |
Working on a 220. The pressure plate splines were shot and looking at the hollow shaft that drives the pto the teeth are about half worn out. Is this part available? Anyone have one? Looks like its AGCO part #70253242.
Also, I measured the fly wheel to check for wear. I was told it should be 2.042. Mine measures 2.049. Is seven thousands enough to worry about? Thanks!
Edited by Joe(OH) - 10 Mar 2016 at 6:52pm |
Life is simpler when you plow around the stump.
DrAllis
Posted: 10 Mar 2016 at 7:01pm |
Hi-Capacity clutch rebuilders(Iowa) can probably refurbish it with a new splined end and then change your pressure plates hub to match the new repaired shaft. They'd likely make it the same as an IH 10-1466 tractor, which are commonly repaired like this.
Joe(OH)
Posted: 10 Mar 2016 at 7:56pm |
Doc, do you know if it can be removed through the torque housing or will the transmission have to be removed?
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
Posted: 10 Mar 2016 at 8:02pm |
Joe, the hollow shaft will come out the front.
MACK
Posted: 10 Mar 2016 at 9:13pm |
If you replace the clutch, have the flywheel resurfaced and new pressure plate. MACK
