allis model b trans oil
aplecider84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aplecider84 Quote  Post ReplyReply Direct Link To This Post Topic: allis model b trans oil
    Posted: 05 May 2010 at 9:48pm
i need know what kind oil goes in the trans of a model b with a hyd att. and in the final drive pans                          thanks!!!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:52pm
You can run the 821 spec for tranny - it's good for all those applications; final drives - SAE 140.
WC, CA, D14, WD45
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 10:10pm
The factory used 20w non-detergent motor oil in the transmissions for the ones with hydraulics.
Today alot of folks are using universal hydraulic/transmission fluid.
I still use 20w non-detergent motor oil.
Seems to do the job. Tractors are over 60 years old with no transmission or rear end failures.
For the final drives the factory use 140w gear oil for temperatures above 32 F and 90w for temperatures below 32 F.
Now you can cover the whole range with 85w-140 gear oil.
Edited by Jeff Z. NY - 05 May 2010 at 10:20pm
This page was generated in 0.056 seconds.
