allis chalmers garden tractor |
fabricator2009
Joined: 05 Mar 2016 Location: Mentone Indiana Points: 2 |
Topic: allis chalmers garden tractorPosted: 05 Mar 2016 at 8:01am |
Morning. I'm new to Allis Chalmers. Looking for my first garden tractor. I really like the 620, 720 styles. Anything I need to look for, stay away from? If anyone has something for sale . let me know. Thanks.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11416 |
Posted: 05 Mar 2016 at 1:34pm |
Go to the clasified section there was one for sale
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 05 Mar 2016 at 9:08pm |
Garden tractor OR lawn tractor????----Garden tractor would be the 900 series, I use a re-powered 917-H to garden with but lawn unit is a 516 -H and wont do gardens . thanks; ac fleet
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 06 Mar 2016 at 10:41pm |
620/720 will do lawns or gardens. Mower deck cuts 60" and does an extremely even job. I just bought a very old and worn 48" rototiller for rear last fall, and it does a fantastic job with the garden. Attachments are quite expensive, but very heavily built.
This is a very large frame tractor, and may be too large for some small areas. Doesn't take long to cut a lawn when you mow 60" at a time. Generating systems are very touchy on these. (mine included-doesn't work) A lot of owners have put a small alternator on to cure this problem. The toggle/safety switches are getting old, and stay open and can cause a failure to start sometimes. Relays are sometimes added into the ignition system to work around these. I had done this, until that quit working also. I then added a separate wire from ignition switch to starter with fuse inline to eliminate this problem. (probably not a good fix if you have young children around who can use the key in the ignition to start tractor) I don't have any little ones around. My Onan seems to generate a lot of power, but repair parts are extremely expensive. You may see some owners re-engine with Honda, Kohler, B&S if their Onan is really gone. Cummins now owns Onan. I believe Small Engine Warehouse sells kits for this. These series tractors have a 3 speed manual transmission, with a Sunstrand hydrostatic transmission, giving a tremendous variance of speed and power. You can crawl along, yet have tremendous power at your hand. Guess you can tell I really like mine, even tho I don't have a working charging system.
Edited by macvette - 06 Mar 2016 at 10:43pm |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1898 |
Posted: 07 Mar 2016 at 7:02am |
I will have a 616 for sale in the next couple months as soon as I get my 2nd one running
NATHAN CAIRNS
Joined: 07 Feb 2016 Location: Brighton IL Points: 104 |
Posted: 07 Mar 2016 at 12:11pm |
b212's were made in the 70's and are great I have one, but I also have an old 6 something hydro with a mower deck that I plan on fixing one day
B212, WD45, B, 912 Hydro
NATHAN CAIRNS
