mower for a CA
Lincoln View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lincoln Quote  Post ReplyReply Direct Link To This Post Topic: mower for a CA
    Posted: 05 May 2010 at 5:48pm
Does anyone still make a nice belly mower for the CA?
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 5:50pm
I think the Woods L59 is a very good mower.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:02pm
go with a woods l306. an L59 is to narrow. Woods still makes them . You'll have to order it though. Spring the extra bucks for the Manual lift and guide wheeles. The L59 mows fine withou the wheels but a L406 bounces left to right to much without them. You don.t need the blades turning to lift with a manual lift. but hyd s need the PTO to operate.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:38pm
I have the Woods L306 with hyd lift on a CA and think it is the best mowing setup out there for the money. It is 72 inch cut, the L59 is only 60. In average yard grass I mow in 2nd gear.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:00pm
An L503 will mount on a B or a C so I would think it will mount on a CA also. It is a 60 in cut. I don't know what the difference is between the L59 and an L503. Can't believe it is on one inch in width of cut.
