Att. Tracy Martin- Speco 3 point
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Att. Tracy Martin- Speco 3 point
    Posted: 05 May 2010 at 12:03pm
Tracy: Here is the pictures of my Speco 3 point units, one mounted and one not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 12:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 12:05pm
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:42pm
Dave/ Tracey. That looks like it BUT It does not have anything to go snap into the bell.  It looks like it bolts to back of tractor or something.  It also uses a different type top link that goes around shaft on back.  Its about a foot long.  I see how the extra links hook to the lift arms, and the balls with different size holes in them..  The top link wheel is not nearly that big on this one.  Same paint but it says AC 1423 on it where I can see 429 on yours
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:11pm
Tomorrow I will get that entire number off of the yellow unit.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 10:48pm
Thanks Dave, I had never seen one of those. Seems like alot of work . How does it work geometry wise? Does it bole to drawbar bail brackets? Thanks Tracy Martin
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 6:41am
Tracy, I have one of those on my D17D III. It was also on a D14 originally. Works great. Needs some tightening up. Mine doesn't have the braces from the top to the axle bolt, but may have soon. If you need to look at it let me know. Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 6:48am
It is very easy to install. Just snap into bell, install the pins that you install for a drawbar, and then bolt on the two braces on top. I didn't realize it used the two braces until I bought the second unit. It is very stable, you just tighten the sway bars to desired stability and nothing moves. It works perfect for my Bush Hog AT99.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 7:14am
Does the traction booster still work with this type of 3 point?
Edited by Matt MN - 06 May 2010 at 7:14am
