D17 and mower/conditioner
Ed S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed S Quote  Post ReplyReply Direct Link To This Post Topic: D17 and mower/conditioner
    Posted: 04 May 2010 at 8:48pm
I have my eye on a NH 469 mower/conditioner - that has a 9 ft bar. It is in decent shape and the price is good, but...
I have an original D17 with only single action hydraulics. It seems like a lot of machine for the tractor. And, I've never used anything but the lift arms with 3 pt adapter for my sickle mower, shredder, blade, etc.
I assume I can get a single action cylinder to lift the cutter head. Surely that's how the hydraulics work, isn't it?
Do I have enough horsepower to lift it? How about to run the mo/co?
thanks.
Ed S
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:51pm
The tractor will run it no problem, however the low volume hydrualic pump will take forever to lift the stock cylinder.  If you find an AC cylinder that operates on low volume/high pressure hydraulics, you shouldn't have any problems.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 10:16pm
 Ran a 9' New Idea in the past and our 1209 9' JD haybine last summer with the D17 & had no problems...Harvey
P.S. had to throttle back so I didn't knock that JD fine!
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 6:40am
Ran a Ford 535 haybine with a series one D15 for years. Great setup. the D15 has good power for it and the power steering was next to none
1968 D15D,1962 D19D
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 7:59am
I have run a 9' new holland 488 haybine with a D-14 in fescue in pasture fields. It has the single hyd. outlet and lifted the mower fine. The thicker spots really worked the D-14 but did the job. I stayed off the steeper parts and let the dew dry off. The D-17 will be heavy enough the haybine won't bully it around.
Ed S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed S Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 9:45pm
Thanks, guys.
Sounds like it's worth a try.
Ed S
