d12 exhaust manifold mounting bolts
Travo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travo Quote  Post ReplyReply Direct Link To This Post Topic: d12 exhaust manifold mounting bolts
    Posted: 22 Feb 2016 at 11:10am
Are the two inside bolts for the exhaust manifold, on a D12 wet bolts? If so, is there any suggested method of sealing the threads?
I recently had the head rebuilt. After putting everything back together and putting coolant in, I noticed that there is coolant leaking from the bolt holes (while bolt is in hole). If I take a bolt out, fluid gushes out. I assume that they pass through the jacket.. Can anyone confirm this.
Thanks,
Travis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 11:13am
That is common with them. Use a good non hardening sealer like Permatex brand. Tighten the stud down before installing manifold, you won't have any proiblems. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 12:01pm
There shouldn't be any "bolts" there. Use a stud and do like Tracy said, bottom the studs out in the threads but don't torque them in place, just snug them in the bottom and then torque the nut.
This page was generated in 0.215 seconds.
