170 early gas hydraulic and tranny oil
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: 170 early gas hydraulic and tranny oil
    Posted: 03 May 2010 at 9:19pm
I drained the oil and water out of the tranny, hydralics and power director, how much oil is needed and do i put it in the dipstick hole in the tranny to fill all three?  The level was so low that it would not read on the dipstick.
                                                Kurt
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 9:34pm
24 qts in Transmission,26 qts in Torque Housing.Differential lubed from Trans.PS uses Hyd oil supply, might still have oil/water in PS unit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 9:41pm
2 seperate filling locations, Hyd. oil left/forward of shifter. Trans on right. Did you hit all the drain plugs? Are you installing new Hyd oil filter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 12:53pm
I think I have drained all points (3) and I have a new filter ready to go. Is the second fill point on the top of the tranny just in front and to the left of the shifter? this looks like the vent to me.
                         Kurt
