HD5 ether hose
serioussam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Topic: HD5 ether hose
    Posted: 06 Feb 2016 at 9:38am
not sure if anyone has done this wth their
hd5 , I pulled the 1/4" plug out of the air intake
and put in a 1/4" pipe thread to 3/8" air line fitting.
I then put on a 3/8" fuel line about 3' long and
ran i it up through a hole in the dash .I then made a
wood plug to put in the end of the fuel line. My hd5
starts with very little ether now in the cold weather
Post Options Post Options   Thanks (0) Thanks(0)   Quote serioussam Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 9:53am
Eric B View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 12:35pm
I agree what you have done works very good. I have done the same to some of my equipment. Like you say it does not take much ether when none is wasted. I was tempted once and did the wrong thing when running out of fuel in my truck with a Detroit 6-71. I was painfully close to the fuel station and used a bit of ether to restart the truck without bleeding the lines...the long and the short of it - the blower gasket failed Cry. Thankfully nothing worse happened but I confirmed the advice that you never use ether to a hot engine Ouch
This page was generated in 0.297 seconds.
