D 12 series 111 starter
logan d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote logan d Quote  Post ReplyReply Direct Link To This Post Topic: D 12 series 111 starter
    Posted: 01 May 2010 at 2:21pm
 Still looking for starter for series 111 late model, would like to hear from someone who has rebuilt  a starter the # is 1107265 delco. the 10 tooth drive gear dosent work on this tractor.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 3:01pm
I've got a D-10 series III. I've replaced the started bearings on it. Not that  hard to do and made a big difference on how well it cranked over.
One bearing will drive through and the other run a tap, 5/8" NC if I remember right. Then turn a cap screw in and pull the bearing out.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 3:51pm
Starter drive should be a easy replacement, on HD4 starter I found rebuild shop that had them in stock. One pressed cage for clutch and other with heavy duty snap ring clutch.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:46pm
Call any Agco dealer that is qualified, they can get it for you.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 7:07pm
 replace the drive gear  have them in stock   1-800-254-3116  sometimes a small amount of lube helps a lot
