Dyno transition.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Dyno transition.
    Posted: 30 Apr 2010 at 11:11pm
A few years ago I went in with 5 other local fellows to purchase a dyno. Did anyone ever make a conversion or apparatus to hook a belt pulley to a modern day dyno? i have several old tractors with belt pully that don't have a pto.  Dave.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:30am
YES
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:46am
Yes Dave M & W made a unit just for belt tractors. I used one years ago at the Johnne Deere store in Lee's Summit Mo. back in 1976. It was just a shaft with a pulley on one end and had two pillow block bearing and the other end it had a 540 PTO to the dyno,
The unit was setting on A frame that was staked down.
Don
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 7:34am
I think some sawmills used a setup like that.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 9:57am
would both pully's need to be the same size, right?
