Marvel Schebler TSX-464 - Will it Work?
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: Marvel Schebler TSX-464 - Will it Work?
    Posted: 30 Apr 2010 at 4:21pm
What is the consensus here....
Tractor, WD45, has not run in 10-12 years. Think she would run again without rebuilding the carb? It looks OK, no critters inside. Just put it back on, clean the tank, new fuel line and go. What are the chances?
Any good success stories out there?
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 4:40pm
Jeff - my Gleaner EIII sat in a shed longer than that and I didn't touch the carb other than remove the drain plug and run some fuel out of it and it runs great.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 4:42pm
I would rather be lucky than good any day but I am usually singing whom despair and agony on me deep dark depression constent missery oh oh.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:59pm
Depends how the carb was set up when the tractor was parked.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:10am
If it wasn't run dry, there's a good chance there's varnish in the jets and the seat for the float needle valve. You can test the float needle valve to see if it opens and closes without taking anything off or apart, just take out the float bowl drain plug and turn on the fuel valve at the tank with gas in the tank and see if you get a flow the size of a pencil for 5 minutes (catch that gas and recycle it back to the tank). Then put the plug in and see that the carburetor doesn't overflow. Another place for varnish to have gathered (even if run daily for the last 30 or 40 years) is the inlet adapter screen.
Gerald J.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 5:17am
you may need to clean the points to get spark. file with an emery board or points file, wipe clean and see what happens. sitting so long can make them not have a good contact and no spark. good luck!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 6:34am
Jeff,
I got this old WD-45 at a farm sale just for the power steering, Got it home before I removed the steering unit decided to start it up and see how good it was, I didn't put the radiator on it because the tractor was just parts or so I thought, put some gas in her and a old Batt, she fired right up I ran it for maybe a min or two and then realized just how good the old tractor was running! I now use this tractor around here the most. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 7:00am
If you looked in the carb and there wasn't much debris or rust especially, a quick roto rooter with a can of Gumout or you favorite carb cleaner should clean it up pretty quickly to at least get the engine fired and see how it runs. Ya never know, you might be okay. Me personally, I would go through it top to bottom, install it, and that's one thing less I'd have to pull back off later. But, that's just me......
Steve@B&B
