will a wd45 piston, rod, crank go in a wd engine
patmorrow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patmorrow Quote  Post ReplyReply Direct Link To This Post Topic: will a wd45 piston, rod, crank go in a wd engine
    Posted: 26 Dec 2015 at 2:55pm
will a wd45 piston, rod, crank and sleeves go in a wd engine without any issues
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 3:10pm
Yup. I recommend doing all 4 though.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote patmorrow Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 3:48pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote patmorrow Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 3:50pm
Are the gaskets all the same for the wd45 and wd
Are the o rings the same for the 45 sleeves
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2015 at 5:35pm
Be careful on the sleeve O-rings. The OEM WD or WD-45 4 inch bore sleeves are exactly the same and use the same O-ring. If the sleeves are 4 1/8" bore, they take a different O-ring (a thinner one).
Post Options Post Options   Thanks (0) Thanks(0)   Quote patmorrow Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 7:01pm
Thank you.  Any other advice on this build would be greatly appreciated
QUOTE=DrAllis]Be careful on the sleeve O-rings. The OEM WD or WD-45 4 inch bore sleeves are exactly the same and use the same O-ring. If the sleeves are 4 1/8" bore, they take a different O-ring (a thinner one).[/QUOTE]
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 10:09pm
On the 4 1/8 sleeves the m&w used a thin o ring, and I've seen 2 other sizes of o rings on the other sleeves. I just machine the o ring grove on the sleeves slightly and use a 3mm x 102mm buna o ring from McMaster Carr on all of them. I had gotten a couple different sizes close after measuring and found the one that worked best. Now I may be wrong on the 3x102, I'm just going from memory, I'd have to look at the bag to be sure.
