need engine for 8070
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: need engine for 8070
    Posted: 28 Apr 2010 at 2:42pm
I recently bought an 8070 FWA, thinking that the engine would be rebuildable, but like my usual luck, not the case. Block is shot, crank is shot, not much to work with. Any one have or know of something to get me going, either to rebuild, or good used to bolt right in. What combines used the same engine? I want to keep it as right as possible, not something way off factory. Thanks in advance.  Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 2:50pm
Some L2, L3's plus all the N5 & N6 used the 426.  You probably going to need keep the front plates, etc. off your 8070 block if you go the combine engine into a tractor route.  Those on here that know more will post better answers.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:50pm
this # 217-663-8540 is for a posted who has 3 n6 engines, should work
