Things you find in gas tanks
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Things you find in gas tanks
    Posted: 22 Dec 2015 at 5:57pm
Like this big old yellow jacket, it's been fermented and hard as a rock that I found in a WD gas tank. lol
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 6:18pm
Thats enough to drive a man crazy trying to figure out why his tractor runs a little while and quits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 7:26pm
I hadda big ole carpenter Bee (Bumble bee) that would suck down the drain, when the tank was about a quarter full, on the D-14.  Bout drove me crazy one fall.  Stuck a camera down into the tank to see him, pulled him out with one of them choke cable grabber things...
jkoby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jkoby Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:20pm
Had the plastic cap for a five gallon gas can break off several years ago. Forgot about it until the tractor wouldn't run. Found it stuck in the valve for the fuel shutoff recently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:45pm
Asian Beetles the last few Autumns
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:10pm
How about 2 gallons of dirty water. The 190 i receantl got kept having water in the sediment bulb. I pulled it out  in the past some one had added a 2' tall tube to the valve. I pulled it and got 2 gallons of water out of the right side.  put a new valve in and draind it every day for a few days. now I get clean fuel out. Ill change the left one in the spring. it too cold to mess with it right now.  looking in the fuel cap it looks like they put about a 10' tall tube on it.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 10:00pm
why do ya'll leave the caps off yer tanks? how do them bugs gits in there? lol
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:44am
I had a plastic button off a coat show up in a D-15... would run until it sucked back in the hole...if you know there is a riser in your tank..you need to flush it once in a while by taking the sediment bowl off completely...Mark
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 7:51am
Ford 5000 I bought had developed a seam leak during the winter so I just put a little fuel in it to do some thing till late spring. I removed it after draining all I could out of it.
After I removed it I turned it up side down to plug the out let and do the cleaning then add seal. Some thing was rattling around in there and I wasn't able to shake it out I get a flash lite and look inside and find not one but two of those fuel can caps with the plastic thingies so they don't fall off the spout.
   Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:29am
This was not one of mine tractors.lol
But if I had a big old bee come around as I was filling a tank I'd let him have the tractor for as long as he needed it.lmao
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:39am
10-4 on the BEE!!! I'd let the bee have the tractor also Don, I let an entire army of jellow jackets have a WD-45 and bush hog one time. Merry Christmas everybody.
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:45am
The only thing i ever find in gas tanks is holes.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:55am
Feed sack strings and strips. Plastic hydraulic hose caps. Electrical tape. Asian beetles. Don't know how any of it got in the tanks. Also a 9170 that had a dollop of silicone floating around in the tank. That was a factory screw up.
Wink
I am a Russian Bot
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 10:09am
I've recovered many fuel gauges.  Well, actually just sticks, but I bet I know how they got there.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 5:26pm
Jim sounds like a case of stick to short...
Well I haven't found anything bad in my tank since I started using a funnel with a strainer before that I found several bits of grass in the carb that didn't help the needle seat any better.. bit filling it up in the middle of the hay field I'd didn't surprise me much.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 8:19pm
Can't believe I haven't read this yet....an END WRENCH!!
Galatians 5:22-24
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 9:46pm
When I bough grandpas cub off grandma ( yeah wrong color I know ) my uncle had tock it to his house for some reason, It been siting a few yard in his yard when I got it. I got all kinds of sicks rocks and acorns and stuff out of its gas tank. Compliments of my little cousins I'm guessing lol.
Edited by Wdtractorman - 23 Dec 2015 at 9:46pm
