Model B loader
Scott in MA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott in MA Quote  Post ReplyReply Direct Link To This Post Topic: Model B loader
    Posted: 28 Apr 2010 at 9:44am
I'm going to look at a loader for my model B. I haven't seen any photos, but the seller says it's all there, complete with PTO driven hydraulic pump. It needs some sanding, cleaning, and painting. I haven't seen many photos of Bs with loaders. The loaders I have seen all look the same, like they might be the same make and model (lightweight with trip buckets).
Does anyone know whay company or companies made loaders for Bs, how common (or not) they are, and what one might be worth? I realize the last part is hard to answer. This will all help me to make a reasonable offer. Thanks!
Scott
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 10:22am
The most common one that I see was made by the Henderson company.  I can't help you out with the price though.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 10:40am
Scott, We did not sell loaders for the B.  However, there are some made that were quite successful.
Be certain you have all the parts - the pump, hoses, valves, and mounting frames.  Some of the mounting frames get lost on the tractor so be certain you get those.  Look at the frame to be sure it is in alingment.  Storing them may bend them.  Also, take a good look at the bucket to be sure it will release and snap back into place.  They are usually mechinical not hyd.
As to the price remember you are looking at something many years old and it is almost catch as catch can.  How much do you want it.  That usually determines the price.
To me it seems that several hundred is about right but that's from an older mind.
Let us know how it goes.
Take good care of my favorate.
Good Luck!
Bill Long
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 4:57pm
Scott Listen to Bill L he knows what he is talking about. I have a Henderson on my B, I did much work on it including making new lift arms, the old ones were welded where the bend is. A tractor friend said to remember that the more rediculous they were to begin with the more collectable they are now. Mine is for show only.  Mark L
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 5:37pm
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 8:37pm
Henderson by far made the most. I've also heard of some Farm Hand and maybe even a deerborn loader for a B. I have a henderson and when I had it hooked up it was pretty darn handy. It will lift more then you should though. The B was not meant as a loader tractor, and if you lift heavy loads, it will put a LOT of stress on the torque tube. I have talked to the preveous owner of mine and he said if I ever decided to get rid of it, he would like first dibs on buying it back. I would take anywhere between 200 to 500 for one. But mine is REALLY nice. Painted very nicely, has all original tags and the hydraulic pump goes with. So thats at least a ball park for you.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:18pm
Here is the B and Henderson Loader I used to own...
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:28pm
As stated by others the henderson was the most common, I think because it was cheaper than others. I remember my Dad looking at literature at different dealers ,them buying a henderson for our Farmall C, it came on a skid and he and gramp put it together. Soon after Gramp stripped the steering geer. light tractors were not made for a loader. I had a henderson that came with a parts tractor and I sold it for $300. and the bucket was rough. I have one that I would like to mount on a B that has a name tag that says brackett& shaw, it has short cyls. that push from a low frame that hangs from the plate at the front of the engine, Cal in Ct
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:34pm
Forgot to add, you are going to want wheel weights, fluid in your tires, or both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 9:36pm
Here is a copy and past of an ad for a different style of loader I just saw (not mine):
Nice tractor with loaderAllis Chalmers B $1400 (New Berlin)
Date: 2010-04-28, 10:54AM CDT
Reply to: sale-mnaes-1714421207@craigslist.org [Errors when replying to ads?]
I have an Allis Chalmers tractor with a full hydraulic loader (3 rams). I got this tractor about 5 years ago and it always ran fine I used it to remove snow and move some dirt around. It was a county tractor that was rebuilt by the previous owner it has almost new back tires with tire chains power steering and a very nice full hydraulic loader. I think it has some type of 3 point hitch and a PTO shaft out the back also. The tractor does turn over but does not start. This tractor does need some work I think the carb needs to be rebuilt. Let me know if you would like to take a look at it. Thanks
  • it's NOT ok to contact this poster with services or other commercial interest
