180/190 ring gear brass rub block
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Topic: 180/190 ring gear brass rub block
    Posted: 21 Dec 2015 at 9:47am
looking for a estimated size for the brass block in the rear end,  as in length and thickness
 Thanks
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 9:44pm
What brass block u talking about .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2016 at 10:07pm
To insure the ring gear keeps in contact with the pinion you install a block between the back side of the carrier and the rear end housing to keep it from spreading apart under high horse power/ torque other wise the pinion will clean the ring gear teeth off
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 11:55am
O OK never heard any one here doing that but we ant run but around 250 out of the ones here loljust farm class .sorry iI can't help have u talk to Larry wight he may know .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 1:11pm
It's something you won't really need to till you get to high hp mark but since i'm in there and it's staring me in the face I'm going to do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 6:20pm
Been a while since I've looked at one but memory says 3 or more inches tall and an inch square. Whatever it takes to attach to the right sidewall and just clear the ring gear.
