7000 and 7040 |
| Author | ||
sason
Topic: 7000 and 7040Posted: 07 Dec 2015 at 7:13am |
i recently bought a 7000 and a 7040 ps. i seen an add somewhere that someone put a 7030 front axle under a 7000. May possibly put a loader on the 7000 and keep it. 7040 has a locked up transmission or rearend. havent went and got 7040 yet.Anyone know how much work this will take or is does it bolt right up. i thought 7030 and up had a wider frame for the bigger engine. any help would be appreciated.
180 with a turbo and 460 loader.
| Sponsored Links | ||
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 07 Dec 2015 at 8:46am |
7010 thru 7080 have the same frame rails. 7000 have the same as a 190/200.
IG |
8070
Posted: 07 Dec 2015 at 9:05am |
The black 7000 had the big frontend under them.as it can be done . Got one here with the big front under it mess me and I try to help u .
Unit3
Posted: 07 Dec 2015 at 10:40am |
I think if you look in a 7000 book it will tell that the heavy (7010-7080) front end was an option. If I remember it right.
sason
Posted: 07 Dec 2015 at 12:36pm |
just looked on agco parts and the heavy duty front axle has the same part number as a 7040. thanks for the help guys. my 7000 has worn into spindles about 3/4 of an inch and needs replaced. after i get my 7040 home i will swap axles and part it out. then primer and paint. thanks again for all the help
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5115 |
Posted: 07 Dec 2015 at 1:28pm |
This is a 7000 special.
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 07 Dec 2015 at 1:32pm |
My 7000 is a "special" but has the standard front end. So I dont think all specials had them.
Hurst
Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
Posted: 07 Dec 2015 at 9:46pm |
Double check on the bolster, I think it may have been different to accommodate a larger axle pin?
Hurst
1979 Allis Chalmers 7000
5800 Hours |
ILGLEANER
Posted: 07 Dec 2015 at 9:53pm |
I know nothing, we have 5 ,7000
IG |
ILGLEANER
Posted: 07 Dec 2015 at 9:54pm |
That's right Ed. |
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 07 Dec 2015 at 9:55pm |
my 7010 bought new off the lot has the heavy one.
KY poorboy
Posted: 07 Dec 2015 at 10:02pm |
[QUOTE=ILGLEANER] I know nothing, we have 5 ,7000
IG ROFLMAO!!!!!! Get em, John!! |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2422 |
Posted: 07 Dec 2015 at 10:12pm |
The 7000 with the heavy front axle uses a different power steering cylinder. I don't believe that the standard one will work and the heavy one from a 7010 thru 7080 doesn't work right. It steers a lot easier one way than the other. I think that someone had a way to get around this, but I don't remember what the solution was.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Posted: 07 Dec 2015 at 10:28pm |
Different valve to accommodate a different cylinder I would guess. Is it called a compensator valve? I forget.
Wink I am a Russian Bot |
SHAMELESS
Posted: 07 Dec 2015 at 10:30pm |
I gots a heavy front axle for sale off my 7080
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 612 |
Posted: 08 Dec 2015 at 10:52am |
HD front end was also available on maroon belly tractors, have seen several over the years.
