3 point adapter
John Ontario View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Quote  Post ReplyReply Direct Link To This Post Topic: 3 point adapter
    Posted: 24 Apr 2010 at 7:43pm
Picked up a snap coupler to 3 point adapter today, the type that slips into the bell. There is brackets on the lift arms for what I guess is for a stabilizer. Does anyone have one available or is it just as easy to make one.
Thanks
John
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 10:24pm
There was a couple different arrangements for the stabilizer. For plows/harrows they show  "anchor" with chains to bar assemblies [lift arms], and beaming screw to "cross tube", on rakes/mowers, they show "stabilizer" from lift arms to mounts under rear housing. What I did because most of these stabilizer's/anchors were left "hanging in the barn" somewhere, NOT with the adapter, was find a big heavy duty turnbuckle [ like the ones used on roadside cable guard rails] and throw that on in between arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 10:25pm
I may be able to dig up a "re-print" showing these adaptations if you would like one sent to you.
This page was generated in 0.289 seconds.
