H3 dozer update
OldSchoolRecovery View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Topic: H3 dozer update
    Posted: 13 Nov 2015 at 10:08pm
Had a chance to dig into the H3 I picked up at an auction.
Engine stuck, I put a battery in it, replaced ground cable, anyway, turn to start, fan moves about a quarter of an inch, and then back.  Soaked 24 hours with PB Blaster and Carb cleaner (contains acetone) so far.  Hoping it may free up without pulling head, etc.  Will give a couple more days.  Me thinks its number two as spark plug had rust on it.  FWIW, the plugs where new, never run.
Second, the left steering clutch lever is (was) stuck forward position.  I looked into the brake adjuster holes and the left box was half full of water, right was dry.  Looked under machine, right plug was out.  Took left plug out and drained out about 4 gallons of water, no oil, which is good.  Anyway, gave the left steering clutch lever a yank (harder than before) and it freed up.  Probably take the cover off the box and give it a shot of blaster.
The tag (if believeable) said stored insice for many years, not run since put away.  It did however sit outside at the auction site for at least a month and we did have a couple torensial rainfalls during that time.  Still can not believe that much water found its way inside there, but no cracks from freezing, so I think it should be all right.
For future reference, is it ok to run with out he plugs??
For now, wait out the frooze cylinder..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 10:10pm
That would be "froze" not frooze.....
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 4:50am
Ya never knoow it might be frooze real good...Wink
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 8:39am
leave plugs out unless you are working in water area ie creek, swamp etc. left clutch will probably be ok once water is drained and unit is  worked a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 4:21pm
Thanks, will do.
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 4:22pm
So, day three. No movement yet.  Got called into work tonight, so now probablly Wednesday if no movement will pull head..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 10:27pm
Took the motor apart today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 10:29pm
Trying to load picture..
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 10:33pm
Well, not very successful.
Anyway, two and three pistons stuck to sleeves. You can see the sleeves move up and down when toggling the start switch.
Rocker arms and shaft look the worst from condensation rust.
Probably replace all four piston sleeve assemblies and rod bearings..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 10:34pm
And send the head out to get freshened up, etc..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 12:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 1:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 1:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 1:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 1:03am
Hit or miss on the pictures, but here are some.
cb1
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 3:55pm
That head looks good...freshen up is a good thing. Depending on how much you want to play around...you could probably get the engine nicely loosened up for good running but if you're looking for perfection - only new parts will do. If the "stuck position" is high up in the liner you'll be able to clean it up nicely. With bolts and flat bar you can lock down the liners that want to come up. I had this same thing on a 201 cu. in. The piston stuck position was a little too low on the liner. After getting freed up and started that piston/cylinder had too tight of a clearance on engine warm up resulting in a bearing knock. Other engines came back to life ...no issues or oil consumption.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 4:43pm
I see where I can get single piston sleeve kit for less than a set of 4.  And I can get all of the parts individually cheaper than a complete set, so I may just replace whats needed, etc.
There is absolutly no ridge on one and four, two and three have enough pitting, that I would not want to use again, so I may just change out two and three.  Neighbor is a machinist, may have him measure one and four and go from there.
cb1
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 4:52pm
We recently removed a stuck engine from a D grader. The cam lobes were rusted, the lifter faces  had rust, the cam gear, several pistons were stuck in the sleeves and the crankshaft was cracked about  150 degrees of the circumference. When you tear down a stuck engine, it is a pandoras box. The H3 may have been parked due to low oil pressure and if that is the case, then it is cam bearings, mains, rods , etc. Unless you completely dis assemble it, you won't know what you have. Our HD-3 is my favorite tractor and since these  are so much fun to own and operate, you want it to be dependable. The engine is the heartbeat of any tractor. You want it to be beating on all four.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 5:53pm
Kinda looks like it was sitting out in the weather, with no rain cap on the muffler...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 8:20pm
Depending on the plug size of the rear case (HD4 was 2") If these are the same I would find some 2" barrel bung plugs and install - drill several 1/4" holes for drainage but small enough to exclude mice
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 10:23pm
I like that, sounds good.
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 10:26pm
It had a muffler and rain cap, however, and automotive oval muffler with rolled end cap that actually held water, etc.  So, Im thinking some of that water found its way into two and three.
The stock muffler has a molded end as you know.
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 10:34pm
I understand your post, however, that could be a endless $$$$ rathole. I in the past have allready stuck 7G's into a 3G machine if you know what I mean.
I would like to know what else is wrong or weak with the machine besides the motor.  For the limited use it will provide (its a hobby for me) I will probably put two piston liner sets (90 bucks each), couple gaskets and a carb kit and see what happens.
Three hundred bucks onto the 1000 original price wont put me too far in the hole, just to see what I have.
cb1
Edited by OldSchoolRecovery - 16 Nov 2015 at 10:34pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 11:14pm
Old school, Looking at the pics, it doesn't look that bad., just might take a little more soaking as in filling those stuck cylinders and then wait a few day, them come back and tap on them with a wooden block on top... might come loose easier than you think.... and maybe harder than I thought. but it might surprise you how good the pistons are... and as for the liners, maybe just polish them up a bit and blow them out and use them.... if pitted severely, than forget that idea.
 Ages cat made a comment..."The H3 may have been parked due to low oil pressure and if that is the case, then it is cam bearings, mains, rods , etc. " If that motor had low oil pressure, check the intake screen in the sump, check the bypass valve, and oil pressure springs and the biggest one is the little oil pump that is bolted to the back of the engine, it has 2 scrawny little springs that hold the vane blades apart, and had to replace those springs one time because they were next to disintegrated .
 I just broke loose a D7 that the coffee can on the exhaust had holes in it and those holes were directly down the pipe... Old Cat had been there so long that the tree growing up in the frame was 15 years worth of rings on it at 3 ft up.
 Broke it loose, fired it up and drove her out to where we loaded it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 10:40pm
Am going to make a plate and push down (with screws) on both piston at the same time as they are both stuck and they both travel together.  I previously thought one would be coming up and the other down.  If I can break them free and push them down I will evaluate the sleeve finish and go from there.
cb1
I will lathe up some pucks to push against the piston tops etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldSchoolRecovery Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 10:42pm
Maybe even some pictures if I remember as I go..
Deerhunting starts Saturday, so this may be a week or two..
cb1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 12:30am
What I found very effective in loosening the pistons was using the air-chisel on top of one of those "pucks". Using a 50/50 mix of acetone and automatic trans. fluid is awesome for loosening the pistons...just let it sit on top for a few days before you "harass" the pistons :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2015 at 11:55pm
Yup, deer huntin starts saturday... but you got a few minutes at noon and then a few minutes after dark... unless ye gets lucky and bag some of them big bucks out your way. An then you shoulda had the H3 cat runnin to drag em out of the woods or swamps. LOL
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2015 at 7:49am
I had a old john deere 400 backhoe that was stuck like that water ran down the exhaust I used brake fluid to brake them loose
This page was generated in 0.230 seconds.
