Wedge Pin part numbers???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Wedge Pin part numbers???
    Posted: 23 Apr 2010 at 8:37pm
Anybody know the part numbers for the G wedge pin and the CA front cultivator wedge pin? I'm just wondering if the are the same part number.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 6:51am
Charlie: I don't know the part no.s, but Doc Smith sells reproduction G wedge pins.  Dave.
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 11:36am
316356 is the part number.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 11:38am
Sorry, 316356 is for the G.
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2010 at 9:30pm
My cultivator book shows 316356 for the CA as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 7:22am
Thanks guys, I kinda thought they might be the same part number.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 11:54am
Anybody have dimensions for the G wedges?  I'd like to make a set.
cheers,
Creek
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 5:42pm
I have a couple of them. I measure them and get back latter, have a meeting to go to.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 9:58pm
The wedge pins are 6" long, 3/8" thick, 1 1/4" wide at the top, and 9/16" at the bottom. They are not a straight tapper, they are 1" wide in the middle/center. The sides have a slight arch to them. And the edges have a radis of about 7/16"  dia. which fits into the arch in the end of the slot the wedge goes into.
The wide end of the wedge pin has a 3/8" hole 1/2" from the end and centered from the sides.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 7:53am
Dusty -
Thanks a bunch, I'm going to see if I can get a pattern burned out here at work.  I can do the finish grinding at home.  If I remember right there is a light chain that runs to the lift arms so you don't lose them.
thanks again and cheers,
Creek
