WD pulling gears
48ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Topic: WD pulling gears
    Posted: 20 Oct 2015 at 8:52am
Building a WD with a gleaner engine in it was wondering if someone had rear gears that would slow it down. I am looking to pull it in the 4500 and 5500lb classes at 3 1/2 mph. I'm running 15 5's rubber on 38" rims. Was told wd45 diesel rear gears might help me achieve what I'm looking for. Any help would be appreciated.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 10:51am
They won't fit a WD rear end.
The WD rear end is a bastard child.
a 45 rear end is different
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 10:52am
And I hope you have enough motor to turn the 15's at those weight classes. In my area, the clay tracks take a lot of power.
Charlie
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 11:33am
I have a extra wd45 diesel rearend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 3:40pm
Fields sent you a pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 5:27pm
Shorter tires are needed if you can't build the HP for the tall skins.
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 7:23pm
Would it be easier to turn 13.6X38 instead?
how do the farmall h's turn the 38's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 7:54pm
Thanks for all the suggestion. Here where I pull at for one I'm the only AC tractor out there trying to make things work for me. Everyone pulling John deere and Farmall are using 15 5 on 38's and they are winning. Guys with smaller tires don't do so well.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:14pm
I'll tell you this, down here in ga I pull against a lot of john deeres and farmall a with tall tires and my little 28s beat them every time. Just figure out what works best for your tractor on the ground it's pulling in and go for it! Best of luck to you, Ill be trying my first pull with diesel gears this weekend. I'll tell you how that goes after I have some experience haha!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2015 at 8:55pm
Gearing
Charlie
TennMatt1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 4:26am
Ive never weighed one personally but have always been told a diesel rear weighs more. In you situation that may not matter. I know also from my experience here in TN when you get to those heavier classes you start pulling against a lot bigger tractors and in this clay dirt the WC,WD,WD45's shine from 3250-4000 with 15.5 38's. That being said my neighbor has the strongest gleaner E engine I know of and most expensive at $ 12k in just the engine and he can't  place in those heavy classes. Not tying to discourage or say it isn't possible this is just my experience. My 45 weighs 3500 with me on it and I run 14.9 28's and she's stout..Its hard to beat in 4000 lb. and with a new clutch and hand clutch removed it slips the clutch in 5500lb. I was trying to find the back side of the engine and never did. Again just offering my experience. ~MATT~
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 10:22am
Can it be done yes but it takes work and $ I have a wd45 that I pull in 4000-5500 most places and it runs top of the class most times my main competition is a 112 hp U Minneapolis that I hang and can beat with as long as I don't have a sloppy set up but mines no stock tractor so it can be done but it will take more than a stock E gleaner motor mine is 312 cid and has high compression and I still have the stock rear end I didn't put slower gears in the rear and have no problem with power and my 38s and I pull mainly 3mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 7:20pm
I totally agree it can be done but your right on the money part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 7:43pm
I also don't have the money in mine like that one guy has in his I have maybe 10k in my entire tractor and 2800 of that was to fix bad machining
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2015 at 9:27pm
What is the no load ground speed of a wd45 with stock gas gears, "1st gear 2000 rpm with 15.5 Firestone 151 50% tread on 14" wide rims?
Then again with the diesel gears?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 4:59am
with 14.9x28 you get 3.6 mph at around 2000 rpm
with 15.5x38 you get around 4.2 mph
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 5:01am
15.5 with diesel is 3.5 mph
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 7:51am
Thanks Charlie for the info on the diesel gearing speed. Not having any luck here in PA locating a complete diesel rear. Any idea where I could find one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2015 at 8:58am
If I knew I would have it :)
Good luck on your search.
Charlie
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 4:55pm
I  have  2  complete  WD-45  diesel  rear ends +   1 set  of rear   gears  removed from  housing.    Tony
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 5:02pm
I read a article about removing the hand clutch and indtalling a wc trandmision in its place sounded like a neat set up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2015 at 6:16pm
yes it is neat. I'd like to find a cheap WC tranny to try it
Charlie
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 2:55pm
This past Saturday I top out at 6.5 mph. WD45 diesel, 2nd gear, 18.4 x 28 tires 3/8 thread hight
michel.forest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michel.forest Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 5:15pm
find a d-17 series one or two. same pinion and crown as wd-45 diesel and same speed with same size tires
