D-19 Final Drives
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Final Drives
    Posted: 20 Apr 2010 at 3:19pm
How do you check the oil level in the final drives? The fill is under the seat.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 3:30pm
There should be drains at the bottom..you might have to drain the oil out to see what you have...level wise and see the condition of the oil then dump it back in.
Edited by Austin(WI) - 20 Apr 2010 at 3:32pm
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 3:34pm
Unless there are secondary plugs at the top of the casing that alows you to see if oil comes out/ put you finger in it.
"Better By Design"
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 4:20pm
Yup, there are drain plugs at the bottom outside of the final drive casting, there are also level plugs about half way up the casting on the rear outside of each one.  They might be low, they might be high, if the pinion shaft seals leak they could be overfull.  There are two large plugs on the top of the rear housing, they are the fill plugs and also the breather for the final drives.  HTH
