how to test CA hand clutch (Value?)
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: how to test CA hand clutch (Value?)
    Posted: 08 Oct 2015 at 8:16pm
Test driving a CA tomorrow.  Can someone tell me how to operate and test the hand clutch to see if it's working properly?  I know nothing about this hand clutch operation.
Edited by Hubnut - 09 Oct 2015 at 2:31pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 8:41pm
I imagine it's just like on a WD/WD45. Push or pull to go/stop. Not sure which direction is stop and which is go, but someone will chime in!
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 8:50pm
I DON'T IMAGINE it is like a wd/wd45. ca is altogether different animal. pull lever back and hold back to stop. gently release foreward to go. It is also a small dry clutch on the right axle so don't abuse it. wd hand clutch is a wet clutch between foot clutch and transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 9:00pm
Thanks.  Okay, so I drive the tractor along in gear, then pull the hand clutch (right side over the axle) and it will stop moving but keep the PTO driving--right?  HOw can I tell if it's bad or slipping?  Is there a way to test that?
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2015 at 9:16pm
I am certain there are more sophisticated tests out there but we used to engage the clutch after fully stopped with the brakes on. Course you had to have good brakes but we could tell rather quickly if it was not working
Also, you could re-engage the clutch under heavy load.  That would also tell.
Don't forget to go on a steep downhill drive in third and second gear and throttle back quickly to be certain the gear shifters are not damaged and the tractor not jump out of gear.
Let us know how it goes.
Good Luck!
Bill Long
Edited by Bill Long - 08 Oct 2015 at 9:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 5:38am
Thanks much Bill!  I'm looking forward to it!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 6:36am
Another thing some did with these clutches was to bolt them solid rather than fix one that is worn out. I had a friend who used his CA for tractor pulling and he bolted his so there would be no slipping. After he retired from pulling he had me rebuild the clutch so it now works. All this to say it is possible you may find when you pull lever back clutch may not disengage
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 7:47am
If you do get it, you may find it to be the handiest little tractor. My uncle always said "CA meant it was the Cats A$$". I have three of them. Good luck.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 7:55am
Steve,
 Another orange project? Any thing can be fixed, and we have seen some of your work. Bring it home and the folks on here will help you get it going:) Or at least cheer you on.
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 9:13am
had a 1956 ca 12 volt conv. amazing how much it could pull. took it to a tractor pull would have done good but hand clutch slipped towards the end. still always pulled 2 bottom sc plow & ih feild cult. with no problems after that. very sad now that I sold it     hope to replace someday with a d15
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 2:35pm
Looked at the CA this morning.  It runs and drives.  Now I know why people love the CA.  It really is a nice tractor.  The hand clutch was there, but no shifter for it.  It idled and drove without smoke, but needs some tuning.  I tried to use 4th gear, but it almost stalled before I could get going.  Also, the front sheet metal at the nose didn't quite reach the pedestal support.  Are the C and CA nose identical.  If different, it might have a C nose.  Not bad, but he wants $1600.  I think it's too high.  I was thinking $1200 at most.   I need to think about it and then maybe make an offer.
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 3:37pm
C grill is different than the CA due to the cultivator bosses up front.
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2015 at 4:01pm
Another thing is a CA is what I call a poor mans D10 a little harder to get on but about the same running gear.
This page was generated in 0.168 seconds.
