WD spark plugs
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: WD spark plugs
    Posted: 18 Sep 2015 at 9:45am
Haven't really put much thought into spark plugs on my WD. Have an E3 engine with long reach plugs. Running 1/8 over flat tops, 6 cylinder carb, Barney cam, and electronic ignition. Currently running E3.18's but I am do for a new pair. What would be recommended for this? Sitting around 210-220psi compression.
Thanks Carl
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2015 at 9:55am
I have Autolite 65's in mine. Not sure if they are the best....Was going to try some of the 65x but they were out of stock
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2015 at 12:07pm
AC Delco 44XL or XLS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2015 at 5:29pm
Just picked up a set of 44xl's, we'll give em a go.
Thank you
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 7:24pm
Carl, are you still pulling that XT that you where  running a couple years ago ?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2015 at 8:30pm
Nope, pulled her apart couple winters ago with big intentions and there it sits, going back to stock with it, well, close to stock, might throw an hx35, and 7080 tips in it just for playing with around home, but we bought a Massey Ferguson 2745 with the Perkins V8 in it, that is the next puller.
