Fluid in tires...removal?
MikeinMadisonCo. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinMadisonCo. Quote  Post ReplyReply Direct Link To This Post Topic: Fluid in tires...removal?
    Posted: 16 Apr 2010 at 6:52pm
How or what is the best way to remove the calcium from my 16.9x28's and what do I do with it once it's out?
If the horse dies....get off!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 6:58pm
I took a hose that fits over the stem and put it on with the stem on top, then rolled the tire and let the fluid run into buckets. As far as getting rid of it, take it to a tire center that does fluid tires. The one in town just dumped it in their tank and probably sold it to the next guy.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 7:04pm
I took my tractor to town and they pumped it out at no charge.  Of course they kept the fluid.
Doug A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug A Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 7:15pm
If you want all the CaCl out get it pumped out at the local tire shop. If you can can stand to have some left in a place on the farm you want the grass to die and pull the valve steams and let in run out make sure the valve is on the bottom. Also have a hose to wash the rims and tires off. Then put the valve steams back in the tires and pump the tires back up. Best if done with a portable air compressor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 8:09pm
Mike, I had Williams Service in Colfax dismount my old tires. All they did was hang them in the air and let the fluid out on the ground. It's good for killing grass and weeds. Once I had the tubes out, I used my shop vac to suck out the left over fluid in the tubes. Worked really well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 8:17pm
