AC rivet sample needed
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: AC rivet sample needed
    Posted: 16 Apr 2010 at 11:50am
Hi All,
Looking for a unused sample of rivet # 915701 and 915702 used on the allcrop sickle and I assume other sickles.  Have no idea of the dimensions or where they go on the sickle, but I need to find an aftermarket source for them as they are no longer avaialable. Best way to do it is to send the wholesaler one.
Thanks for any help.
Tom
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 11:59am
Tom the dimensions are listed in the Standard Parts Catalog. If someone else does not post them, then I will publish them here later tonight when I get back to PA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 5:01pm
Glenn,
I dont have that catalog. Any specs you can provide would be appreciated.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 8:40pm
915701 is a #6 countersink 1-7/16 inch long
915702 is #6 oval head and is 13/16 incn long
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2010 at 9:00pm
Thanks!
Hopefully its not an oddball size and I can get easily...
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2010 at 6:17am
Avg number of rivits per lb:
915701      75
915702     112
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 7:30am
Went online with these specs....doesnt look good.
The specs for rivets list all the rivets by dimension only...no such thing found as a "#6" rivet.
Will call a supplier to see if they can cross-ref.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 7:47am
Tom....I have sections and there may be rivits also.  Will check tonight....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:28am
Dale,
If you can be sure they are for the two part numbers I listed that would be great as the other rivet sizes needed I have already sourced. Once I nail down all the correct sizes and their modern equivalants, I will put a document up on the website explaining it all for everyones dancing and listening pleasure.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:08am
Tom,
If I recall, all the section rivets are #6.
Glenn
Edited by GlenninPA - 19 Apr 2010 at 2:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:32am
Glenn,
Could you confirm that?  There are 6 different rivet numbers used on the 66 sickle:
915701
915702
911177
911176
910930
910931
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:37am
I will double check my book when I get back to PA tonight.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 10:14am
Tom - If you can size them, I suggest you try McMaster-Carr.  - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 11:18am
Just as I suspected,
I called Jay-Cee rivet, and they said "#6" doesnt mean anything to them, at least not anymore.  So Im going to need a sample.  I might be able to pound out the originals from the bar, but will need a metal shop to do it.  I dont have the right facilites to  extract a rivet undamaged, if thats even possible.
Gee youd think something like this wouldnt be such a hassle.
Edited by TomYaz - 19 Apr 2010 at 11:19am
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 2:45pm
Tom:  Can't you just measure the hole and let the rivet company suggest the proper rivet?
Edited by Rawleigh - 19 Apr 2010 at 2:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 2:52pm
Tom,
They are all "#6" rivets. Just measure one of the other rivets that you have.... The diameter and head will be the same, as long as they are from the same family.
Glenn
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 3:44pm
I thought all section rivets were the same diameter since they were mostly standardized to 3 or 4" sections. Shoup shows them as 0.211" diameter. Valubilt says 1/4" diameter. John Day says 7/32" diameter. http://www.johnday.com/customer/jodaco/downloads/catalogfiles/DayBook%20catalog/1-Farm%20Equipment%20(1-87).pdf which is close to 7/32". Measure the holes they go in. The rivet needs a couple to 5 thousandths clearance. McMaster-Carr says a #6 copper rivet has a 0.228" shank. But they don't offer any steel rivets that size.
I suppose rivets for guard plates might be a different size yet.
Its clear that most of the internet sellers think they have mower section rivets but their rubber ruler has only marks every 1/8" so they don't know what they really have. I suspect those at Shoup if long enough or at valubilt are right even though they are marked differently.
Its sacralige to say it here, but try a Deere parts department. Farm equipment, not lawn mower. And look for a gray haired parts seller.
Gerald J.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 4:39pm
Call Sandy Lake Implement (888-252-0656)  or other dealers. Some one may have them on the shelf or could do a dealer search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 5:00pm
Ted,
Contacting SLI and a dealer search was the first thing I did. Was able to get three of the rivets.
Glenn,
All #6 may do the trick.  Do you know if any of these numbers below are listed as "countersink":?
911176
911177
910930 (same as 911177 per AGCO)
910931
If one of these is contersink then I think I will have enough info.
Thanks
Tom
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 5:58pm
   Hey Tom, I was look'in at your site and noticed you have 1939-1969 as dates of production. The 60 came out in 1935 (Announced in late 1934) as the High Speed combine, was wondering if you knew this?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 6:15pm
Yep I got a bad date...will fix.. Thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:25pm
915701   CTSK   1-7/16
915702   OVAL HD   13/16
911177  NOW  910930
911176   CTSK  1-3/8
910930   OVAL  5/8
910931   CTSK  7/8
All are #6.  I think this is a military reference for 3/16.  (3/16x5/8=6-10)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:38pm
Originally posted by orangereborn orangereborn wrote:
915701   CTSK   1-7/16
911177  NOW  910930
911176   CTSK  1-3/8
910930   OVAL  5/8
910931   CTSK  7/8
Thats good stuff....When I get the three sizes I ordered I should be able to get it all figured out.  I will publish my results.
PS what does the "HD" for 915702 mean?
Thanks Guys for all your assistance!
Edited by TomYaz - 19 Apr 2010 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:41pm
In my DA cross reference manual I found: #6=.203  So there goes my military theory.  Should have quit when I was ahead....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:43pm
Hey O'man what do you think the "HD" means?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 8:59pm
911177  NOW  910930
911176   CTSK  1-3/8
910931   CTSK  7/8
All show up in the  60 Book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:04pm
Hey O'man what do you think the "HD" means?   HAPPY DAY'S???
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2010 at 9:24pm
C'mon Tom you are making my life difficult!  You got to spend some of that cash on some books man!  Std Abbrv - HD - Head  (as in Oval Head, etc.)
Print out this picture....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 5:43am
Glenn,
Cash?, whats that?  All my cash is in inventory!
Only question I had left was what "HD" means since Orange put a "Oval" and a "Oval HD" I thought there may be a difference...Would love to have that book...how much you want for it?
Thanks
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2010 at 6:03am
My only copy, not for sale right now....
But if you are looking for one, it is titled:
Dealers Parts Catalog
       and
Numerical Index
        for
STANDARD PARTS
Form D-10
It has all the hardware, fittings, bolts, nuts, screws, pins, rivets, etc in it. Comes in handy once in a while.......
This page was generated in 0.153 seconds.
