WD Lift Arm seal part number?
Ron(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(MN) Quote  Post ReplyReply Direct Link To This Post Topic: WD Lift Arm seal part number?
    Posted: 14 Apr 2010 at 8:10pm
My nephew bought a 1950 WD several months ago and finally got it home this weekend. It'll be working tractor but it does need some TLC. Both lift arm rams leak pretty bad and I do not have parts book for a WD. Does anyone know what the seal part numbers might be? If not I'll check with the AGCO dealer in either Smith's Mill or Mountain Lake.
Thanks in advance for any info.
Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:18pm
You might try tightening them up first. I think a channel lock works OK on the packing nut. They will be a chevron packing, not a regular seal.The chevron type packings need to weep just a little oil or they will be torn up.
Edited by CTuckerNWIL - 14 Apr 2010 at 8:20pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:45pm
I with Charlie on the ram packing nuts. I back off the nut first then tighten it up.
But if you still need the packing you can get them form ACGO.You can look them up at ACGO's on line part site.
Or just go to a hyd supply store the packing is 1 1/4" on the ID.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2010 at 8:51pm
Thanks guys! I'll try tightening them before we go any further and see what happens and thanks for the AGCO link too.
Ron
