Back to back WC transmissions
slingblade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slingblade Quote  Post ReplyReply Direct Link To This Post Topic: Back to back WC transmissions
    Posted: 25 Jul 2015 at 10:29am
I am doing a repower on a huber M600 grader. I am going to use a WD motor and frame rails. What I need to know, is what kind of speed will I get with those trannys back to back I'm trying to get down to about 1mph. I do not know the rear end ratio. But what would it to a WD as for speed? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 5:00pm
Normally road gear is 10 MPH and low gear is 2 MPH, so if you run both trannys in LOW gear you should get about .4 MPH .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 6:31pm
If they are back to back, then with both trannys in low it will run faster. If both trannys face the normal direction, front to back, it will run slower in low low. Geek
Post Options Post Options   Thanks (0) Thanks(0)   Quote slingblade Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 10:33pm
I guess I should have said two in a row to be more clear but I think drallis understood what I was trying to say. I am assuming a wc trannys will bolt directly to a wd bell housing?thanks for the reply
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 12:09pm
yes they will bolt up to bellhousing. Reverse to reverse is the slowest forward speed
This page was generated in 0.230 seconds.
