snap coupler/pin hitch blade pics
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler/pin hitch blade pics
    Posted: 11 Apr 2010 at 6:35pm
workes great. The coupler eye pinned up nice and tight into the drawbar clevis.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 6:45pm
Hey CARon, nice setup. I do have an extra pin hitch end that came off of a pin hitch plow. I don't know if the bolt holes are the same but they should be. That might be easier to line up than hour clevis.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 6:59pm
Leon, I just might be interested in that pin hitch end. I hooked the clevis to the eye first, and then mouted it to the tractor. Had to tap it on with a hammer, went onto the eye good and tight, but not enough to damage the clevis at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2010 at 7:49pm
Wasn't the pin hitch hookup holes further forward then the snap coupler eye holes, because they had to make room up for the snap coupler bell being further back then the pin hitch hole.  I know when I got my disk, it didn't have a snap coupler eye on it, and when I tried using the original hole for the pin hitch setup which was already taken off before I got it, it worked but the chains to lift the disk were too far back.  Once I shortened up the hitch and put the snap coupler eye further back it worked fine.  I think if I remember right you use the back pin hitch hole as the front snap coupler hole and then drill a new hole.
This page was generated in 0.426 seconds.
