Allis 620
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: Allis 620
    Posted: 28 Jun 2015 at 9:04pm
Got done mowing today and shut it off. A little later tried to start it and it just clicks. Any suggestions? Thanks
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 9:05pm
Make sure you do not have one of the pto switches on...that's what it sounds like to me but could be something else.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 9:19pm
That was my thought to but they are both off.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 9:24pm
battery
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:13pm
Mine does that occasionally.  I play around with the pto switch as few times and it will eventually fire up.  Might also want to check that you hydrostatic lever is in the neutral position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 8:01am
If you are hearing a click your switches are ok, just not enough voltage to get the job done.
If you don't hear a click you are not getting voltage to the solenoid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 3:33pm
I found the battery cable was broke off at the starter. thanks for the replys.
