d14 gears
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Topic: d14 gears
    Posted: 08 Apr 2010 at 7:58pm
what makes the d-14 jump out of gear and if it jumps out of 3rd and 4th is this also common or a sign of bigger problems . what would be the fix ?
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 8:03pm
  have seen the nut come loose on the pinion shaft   will cause it also  was told it can be tightened from outside
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 9:56pm
The most common cause is people grinding the gears. Over time the tooth rounder on the gear becomes a deep bevel and it will not stay in gear. If this is the case, replacement of the shifting collars at least, and worse case would be to replace both gears and collar. After splitting the tractor, you might as well fix it right.
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 10:28pm
Rear half of a D-14 for sale S.E. Wisconsin (262) 719 3552
This page was generated in 0.119 seconds.
