A/C D15....what to do???
Dantforth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dantforth Quote  Post ReplyReply Direct Link To This Post Topic: A/C D15....what to do???
    Posted: 08 Apr 2010 at 2:56pm
    I purchased my first tractor, a D15, a year ago. I completely redid the back end, hydraulic ram, gaskets, seals, brakes, cleaned and painted and reassembled. I drained all fluids and replaced with synthetics and new hydraulic fluid. Tractor has power steering and a front loader. Everything works and it does not pop out of any gears. All tires are new. Wide front. All repainted with proper paint except for lift arms and bucket. Series 1. Now for the not so good news.... I now hear a noise in the engine when under load. It is a tapping sound and I am suspicious that I may have a bearing noise.
    Question - I now have too much money invested and I have lost interest. Do I sell it as it is or invest a further $$$$$$ to do the crank and bearings and possibly re-do the whole engine before selling?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 3:13pm
Seems like it i a question you have to answer.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 3:19pm
the tapping sound under load could be a loose or bent pushrod-num 1 on my checklist
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 3:21pm
it depends on if your going to sell it or use it if I were to keep it id check into getting the problem fixed either way it sounds like its goin to cost you money id fix it and have a life time of enjoyment out of it if it were me
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 8:50pm
Always fix it cause going orange is going great!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 9:00pm
Sounds like ( pun intended) the noise is not that bad if it is just a tapping sound...what I am saying is, do not make any decisions untill you know what you are looking at ... or listening to.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 7:26am
Does it loose oil pressure while you are hearing this "tapping" sound? Could also be cam bearings that are making the noise.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 7:52am
I tend to agree with Floyd, check it out futher, how is the oil p. ? put it on the PTO and listen with a $3  stethsope (sp) Mark
