? for carb experts
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: ? for carb experts
    Posted: 11 Jun 2015 at 9:04pm
Is there a conversion for numbered venturi sizes? What is the ID of a #29 venturi? Reason I'm asking is I found a possible replacement for this Rumely carb and the venturi is listed as 29/32 ID while the carb specs say it takes a #29 venturi
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2015 at 10:42pm
Not an expert, all trial and error here. Had a feller tell me once that the number on the Venturi is the size of the opening in 32nds. Have drilled out a few distillate accordingly with satisfactory results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2015 at 3:47pm
That would make sense, originally I was thinking it was mm but that seemed too big. I'll have to measure the old one to know for sure but I was still curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 12:43am
Did you find a replacement venturi? I am now in need of one for my Waukesha 6bk. If you didn't find one I may be trying to fabricate one. Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2015 at 4:09pm
No I haven't, McDonald has a venturi for a Zenith 267 that is 29/32 ID and looks similar to mine, might fit with some mods. I measured mine though and the ID is 1.030. I can bring my old one up when I bring that magneto and you can take some measurements, I'd guess the 6BK one would be similar. I'd be interested if you can make one. Are you around July 3rd?
This page was generated in 4.725 seconds.
